Question about Philips 190WV
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same as the original broke. Any ideas ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Got wood I would just build my own...cheaper and you can customize it to your like..
Posted on May 10, 2014
2 Suggested Answers
SOURCE: I have an philips 190WV
i got the same opposite problem. my contrast goes up 100 and i can't change any thing.
have you figured out your problem? if yes, how?
Posted on Nov 14, 2010
Desktop Stand ,any ideas ?
  • You can get a universal wall mount if the stand is no longer available or you cant find one
May 10, 2014 | Philips 190WV
How to open a phillips monitor
with a flat screwdriver inserted at the slot, there are several clips all around on the inside but do it carefully
Nov 15, 2013 | Philips 190WV
The left and right insert part of the stand on my Samsung Syncmaster 403T broke. Where can I get a replacement part. The part no. is BN61-00424 for left and right insert of the stands.
Those aren't easy to find (if at all). Your best bet would be to ditch the original stand and get a VESA compatible mount or stand kit. You can usually get them for cheap on monoprice.com
Oct 23, 2013 | Samsung SyncMaster 214T 21.3" LCD Monitor
No light in Philips lcd 190WV
Has it got power? Is it turned on? Is the PC attached to it? First check all your cables & power outlet.
Feb 06, 2013 | Philips 190WV
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
I have an philips 190WV monitor. From times to times the "brightness option shows up and changes to zero without pressing any button on the monitor. Any ideas ?
Sep 05, 2010 | Philips 190WV
I am trying to remove the base from my samsung syncmaster 953bw the bottom of the stand comes away easily by removing the screw but the part which slots into the monitor will not come out. How do I remove...
I have the same problem as the original poster does. I have no idea how to get the base/stand actually out/separated from the monitor. I have tried pulling pretty hard and it wont budge.
Jun 14, 2010 | Computers & Internet
Gateway pc keyboard
yes you can buy a part for keyboard stand.what you are going to do is buy a new one, or still use the old one.
Sep 02, 2008 | Gateway GT5464 Refurbished Intel Desktop...
Phillips 190wv 19inch monitor keeps on flickering leavind the display not in its full glory?
look at you video output speed.
<Control panel>::<display>settings tab::advanced button::monitor tab
once there it should shown you a slow refresh rate, set higher & the 'flicker' should dissipate, you may find that you'll want to update your video adapter as well.
Jul 18, 2008 | Computers & Internet
Is this a Software/Config/Hardware Problem ?
Apparently someone must have went into your properties, By right clicking anywhere on the desktop, Choose properties and then screen saver and then power options, Once there look into the setting for hibernation,standby,sleep make sure that they are set so not shut monitor off after so many minutes. What I am thinking is when you quit using your mouse for any amount of time it turns the monitor off. I hope that gets you going, If not you can Write back here and ask me again we can look for another solution. Thanks
Jan 17, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
116 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
