Question about GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver XL1800 Nite Lite will not go off
I turn off the auto nite lite feature, turn off the nite lite, and turn off the surface light and it stays on, all the time. The surface light settings will make it bright and dim but will not shut it off when it says off. Any ideas?
  • Anonymous Jan 08, 2008
    how do i turn on nite lite on ge over cook top microwave
  • GE Master
  • 9,098 Answers
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed
without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site,
linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
How do I turn off the nightlight on the bottom of my microwave?
TheAuto Nite Light feature can be set to turn on and off at any time desired.Follow the directions below for set-up:
  1. Press the AUTO NITE LIGHT pad.
  2. Enter the time the light is to turn on. ...
  3. Press the AUTO NITE LIGHT pad again and enter the time the light is to turn off. ...
  4. Press the AUTO NITE LIGHT pad once again.
Sep 16, 2017 | Microwave Ovens
Ge spacemaker nite light will turn off
test the switch for defective and replace or clean the contacts. or course your must unpplugged the power before to test.
see the diagram attached.
God bless you
Jul 14, 2012 | Microwave Ovens
I had the electricity go out in the litchen last nite, and usually, I just go to the basement and reset the breaker. It didn't work last nite. Also, now when I turn on the electric range, a light in the...
It's not a ground problem, but more likely a weak or open neutral connection somewhere. This can cause damage to other connected devices because of excessive voltage, and should be taken care of quickly. You should have a licensed electrician check and repair this, both because it may be difficult to locate exactly where the problem is, and because your insurance policy will probably require repairs be done by qualified personnel.
Dec 30, 2010 | Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver xl1800 microwave. Unit comes on, but no heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Installed a new hmw9305 last nite, no power
Sounds like you blew the fuse. I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which explains the problem, how to correct it and where to get any parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Bosch HMV9305 Microwave Oven
GE spacesaver microwave XL1800, all works but not heating
There are some troubleshooting steps you can take to possibly determine the problem before calling or taking it for service, you need a multimeter and a capacitor discharging tool. if you posses BOTH of these tools,
there are 4 causes for this symptom
1) Transformer
2) Capacitor
3) Diode
4) Magnetron
I can instruct you on how to test and/or replace the first three of these. The magnetron is VERY dangerous and should not be serviced or tampered with except by qualified personel. let me know if you would like to take any of these steps otherwise you could bring it to a repair station.
Hope this helps...Feedback always helps me
Oct 29, 2009 | Microwave Ovens
WE have a GE Spacesaver Microwave installed July 2005. I have tried to replace burned out nite lite bulb. Both bulbs broke from socket as I tried to unscrew. Bulb base will not unscrew. How do I get the...
First be sure the oven is unplugged whenever you are removing or installing light bulbs.
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get new bulbs in, if they don't work, that's circuit board damage which we repair for $39.95 for customers nationwide and you can feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 01, 2008 | Microwave Ovens
Nite Lites won't Lite
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 07, 2008 | Sharp R-1501 Microwave Oven
GE XL1800 Suface light
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jul 21, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
481 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
