Question about CTM Homecare CTM HS-580 4-Wheel Power Scooter
Light is flashing 6 times
Battery says full but no movement
  • CTM Homecare Master
  • 1,263 Answers
Hi,if the controller is a blue finned model called a Rhino, then the following applies...
6 OONAPU Out Of Neutral At Power Up. The throttle was not in the neutral position
when the scooter was turned on. The scooter does not drive.
• Return the throttle to neutral, turn the power off, and back on again.
• Throttle may need to be adjusted (see section 5.1.6).
• Check throttle wiring.
Regards
Rob
www.gewizrepairs.co.uk
And please join me on Facebook https://www.facebook.com/gewizrepairs
Posted on May 11, 2014
We have a pronto m51 and the amber light is on after we unplug it from the wall, and it won't move at all.
Hi flashing lights 8 times (Controller fault.). if the batteries haven't been used for several years U might have to replace them .U can buy a BATTERY LOAD TESTER OF E/BAY cost approx,$36..this will give U an accurate test on the condition of the batteries ,good luck
Nov 08, 2016 | Invacare Supply Group Health & Beauty
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Flashing light error
Download the service manual from Pride's website for detailed instructions on what the flashes mean and how to fix it.
Dec 23, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Unlock
Not enough info to really give a good suggestion. Flashing lights and no movement usually indicates that the batteries are very low. Testing the batteries is the place to start and go from there.
Apr 29, 2013 | Pride Jazzy Select 6 Indoor Power...
My chair was going along fine and then suddenly ground to a halt with just one red light constantly flashing at a steady rate. There is no drive! If you press the horn button a second light comes on but...
If the scooter was sitting unused for a long period of time, the gel inside the batteries may have gone solid and will not allow a full charge. You may need to replace the batteries due to the damaged cells. If you know the brand of controller that is on the scooter, you can look up the lights codes here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 08, 2010 | Pride Jazzy Select 6 Indoor Power...
Battery new cahrging good green light flashes
Hi. How many times does the light flash betwwen pauses? this is a fault code. Check free-wheel lever. Check motor and battery leads and connectors.
Check the resistance through the motor with a multi meter.
Good luck. Neil.
May 09, 2010 | Pride Sonic 3 Wheel Portable Scooter
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    CTM Homecare CTM HS-580 4-Wheel Power Scooter Logo
    142 people viewed this question
    Top CTM Homecare Health & Beauty Experts
    Lawrence Oravetz
    ray gallant
    Robin Hill
    Robin Hill
    Are you a CTM Homecare Health and Beauty Expert? Answer questions, earn points and help others
