Question about Car Audio & Video
Why won't my Matsui (model:mat26lw507) switch on from standby.. just a blank screen?
  • 848 Answers
SOURCE: matsui 19041 lcd tv 37
there is some voltage regulation problem in your tv ......
Posted on Aug 25, 2008
  • 116 Answers
SOURCE: My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Posted on Oct 06, 2008
SOURCE: I have a matsui 26inch
My girlfriend has the same tv and it dosent have digital tv built in.
Posted on Jan 05, 2009
ekcnoel
  • 998 Answers
SOURCE: When i switch on my tv it switches itself to
the power supply of your tv is defective it has a swollen capacitors or leaky transistor.
Posted on Oct 14, 2010
MrARCADIAN
  • 284 Answers
SOURCE: my matsui lcd keeps switching
sounds like a PSU power supply problem could be also one of your LCD lamps are going bad.
Get it checked, if you know what your doing then open it up, and look for bulging caps, or burnt area on the curcuit board.
Good luck
Posted on Apr 14, 2011
Matsui tv stuck in standby
Look what category you are in.
Mar 15, 2014 | Sony MDS-JE330 Mini Disc Player
My matsui m32lw509 TV standby light flashes once when i turn it on then it just stays blank nothing powers up ???????????????
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
My matsui lcd keeps switching itself off and going into standby, when I turn it back on by the remote the standby light goes pale
Good luck
Apr 14, 2011 | Televison & Video
Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
Feb 21, 2010 | Audio Players & Recorders
My Matsui TV is a fairly old model and it does not have the buttons where you change the volume etc. My remote control has stopped working therefore I cannot turn my TV on. I have bought a universal remote...
matsui tv's are usually clones of another make set so you might be able to trace another remote ..try rs components for an original replacement.try switching on using the station up button...farr64
Apr 29, 2009 | Televison & Video
I have a matsui 26inch tv model number MAT26LW507. I was told it had dtv built in but I cannot find or access it can anyone help?
DTV just means that it is a Digital Television (instead of analog). There is no component or part that you can "find or access"
Dec 09, 2008 | Televison & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
