Question about Onkyo TX-SV535 Receiver
Why won't my remote speakers will not turn on?
Never had a problem before. the wiring seems okay, but when you press the remote speaker button nothing happens. Is there a fuse or reset button to use?
simplemitch
  • 752 Answers
SOURCE: ONKYO TX-DS575X - Speaker B not working
You may have blown one of the speakers. Put a different set on them to test this theory.
Posted on Dec 18, 2007
killer_clown
  • 86 Answers
SOURCE: onkyo tx-sv727 Protect displayed
first thing if it says protect, check the fuses inside the system they may of blown .When choosing wire gauge, consider the quality of your components and speakers, the overall sound quality you're trying to achieve, and the budget you're working with. Also, keep in mind the distance between your receiver or amp and your speakers long wire runs can cause significant power losses, and thus require thicker cable. You can use this as a guideline
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
Posted on Nov 03, 2008
smarthome2
  • 1114 Answers
SOURCE: Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Posted on Jul 05, 2009
  • 118 Answers
SOURCE: Onkyo TX SV727 - Remote speakers won't come on
check the receiver setup menu, 'osd' button. youll find a menu item to activate the amp to output for zone2
Posted on Nov 04, 2009
  • 14 Answers
SOURCE: I want to run remote speakers from this unit to my bathroom.
you need to hit the multi-source button, then the soucre (fm/video.dvd etc) and then turn on the remote speakers
Posted on Jan 24, 2010
Why is there no sound from rear speakers?
One of the buttons you pressed probably disabled surround sound
Nov 03, 2015 | Denon AVR-791 7.1 CH A/V Home Theater...
Philips fwd798 does not switch off remote does not seem to operate properly batteries are fine cd tray does not open
Remove batteries and unplug from the wall receptical, allow 60 seconds to pass in a effort to reset the processor ic, if no change check speaker wires on back for shorts, if wiring okay have the unit checked for audio output ic problems.
Sep 02, 2012 | Philips FWD798/37 Shelf System
My Panasonic sa-ak770 will not come out of standby mode
Check to make sure there are no shorts in the speaker wiring, if okay remove speaker wires from back, press power if it comes out of standby the wires or speakers are the problem, if there is no change the protection circuit is not functioning or the audio output ic's have a short.
Jun 09, 2012 | Panasonic Audio Players & Recorders
Rx-v363 powers on then immediately off
The Yamaha receiver is going into shutdown because one or two channels have shorted audio output semiconductors, first check all speaker wires for shorts, if okay! all parts that are effected will need to be replaced.
Apr 04, 2012 | Yamaha RX-V363 Receiver
Jvc kd- r311 lights up and says PROTECT, thats it nothing else works. i have pressed the reset button loads of times and diconnected it and tryed again but nothing seems to make any difference. please...
Check your speakers and speaker wires to make sure there are no shorts or grounds. If the speakers and speaker wires check out, you probably have a bad internal output ic.
May 10, 2011 | JVC AM FM CD DET FACE CAR STEREO
Powered subwoofer doesnt work .stopped a couple of months ago.it reads SW on the amp display.sw is turned on -green light on-wiring is all healthy and snug.home theater hasn't suffered any abuse.always...
I sounds like you have blown the woofer. open the unit and check. first disconnect the leads on the woffer, then use an ohm meeter. If you don't have an ohm meeter use a 9v battery across the speaker terminals. If you hear a thunk when the battery touches the terminals the speaker is okay. If tyou don't it's gone. If the ohm meeter reads some number like 4 to 9 the speaker would be okay. If it reads nothing or 000 then it's gone. If you need a speaker you can order it from Pro Line Music 215-736-8055
Jan 15, 2010 | Audio Players & Recorders
Jan 10, 2009 | Onkyo TX-DS656 Receiver
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Speaker off
You will need an original Mitsubishi remote. The original remotes usually have 3 large oval buttons labeled Audio (up and down), Adjust (up and down) and Video (up and down). Pressing the Audio button will bring up the usual Bass, Treble, Balance... and Speakers Off. When you see those words press the Adjust button and the speakers will switch to On. Some sets have the Audio, Adjust and Video buttons behind a little door on the front of the set, so check there first and if not, get an original remote.
Dec 29, 2006 | Mitsubishi CS-27407 27" TV
26 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
