Video Game Consoles & Games Logo
Jaxon Reese Posted on May 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is cc - Pokemon Video Game Consoles & Games
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on May 10, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
819015
Points
6396
Why won't my new TV/DVD combo turn on CC but subtitles work fine.
There could be a few reasons why your TV/DVD combo is not displaying closed captions (CC) but subtitles are working fine. Some possible causes include:
  • The CC feature is not enabled on the TV or DVD player. Check the settings on both the TV and the DVD player to make sure the CC feature is turned on.
  • The CC feature may only be available on certain channels or with certain types of programming. Check to see if the CC feature is available on the channel or program you are trying to watch.
  • The CC feature may not be compatible with the type of DVD you are trying to play. Some DVDs may not include CC information or may have different CC options.
  • The TV/DVD combo may be malfunctioning. If none of the above solutions work, it may be a hardware issue and you may need to contact the manufacturer for further assistance.
It's important to note that CC and subtitles are different things. CC is closed captions which is a text version of the audio that appears on screen while subtitles are a text version of spoken dialog in the same language as the audio. Make sure you are looking for the correct feature.
Please can advise torque specific for mazda RF engine
Mazda has a long history of building its own Diesel engines, with the exception of a few units that were built under license.
Mazda Diesel engine Overview Manufacturer Mazda Layout Configuration Inline-4, Inline-6 Displacement 1.4 L (1,399 cc)
1.6 L (1,560 cc)
1.7 L (1,720 cc)
2.0 L (1,998 cc)
2.2 L (2,184 cc)
2.2 L (2,209 cc)
2.5 L (2,499 cc)
2.5 L (2,522 cc)
2.7 L (2,701 cc)
2.9 L (2,892 cc)
3.0 L (2,956 cc)
3.0 L (2,977 cc)
3.5 L (3,455 cc)
3.7 L (3,663 cc)
3.8 L (3,783 cc)
4.0 L (4,021 cc)
4.1 L (4,052 cc)
4.6 L (4,553 cc)
5.5 L (5,494 cc) Cylinder bore 75 mm (2.95 in)
73.7 mm (2.90 in)
86 mm (3.39 in)
93 mm (3.66 in)
95 mm (3.74 in) Piston stroke 82 mm (3.23 in)
86 mm (3.39 in)
88.3 mm (3.48 in)
92 mm (3.62 in)
94 mm (3.7 in)
102 mm (4.02 in) Block material Cast iron, Aluminum Head material Alloy Valvetrain SOHC, DOHC Compression ratio Combustion Turbocharger Garrett GT15 (VNT15) variable geometry with intercooler Fuel system Common rail direct injection Management Bosch Fuel type Diesel Cooling system Water cooled Output Power output 45-136 kW (61-185 PS; 60-182 hp) Torque output 108-400 N?m (80-295 lb?ft)
I use my cc a lot, but trying to help a friend understand hers, I somehow messed mine up. Before this all I had to do was press the cc button and turn it on. Now how do I get that back??
Hello Dixie, it is very possible that the CC does not work for you, from the remote control, for failure of the CC button on the remote, try to enter the menu and look for the CC function and try from there if it changes, if it does, it means that the CC button on your remote control works poorly
Try replacing the remote
Greetings Franco Dosil
Hola Dixie, es muy posible que no te funcione el CC, desde el control remoto, por falla del bot?n CC en el remoto, prueba ingresar al men? y buscar la funci?n CC y probar desde ah? si cambia, si lo hace, quiere decir que el bot?n de CC de tu control remoto funciona mal
Prueba reemplazar el remoto
Saludos Franco Dosil
2answers
Why wont my toyota carina 2 ltr. E start its always been so good but we had one hard frost and the next day it would not start with a jump but did start with a tow, the following day went to start it
Not familiar with your specific engine so some of this may not apply. Generally, sounds as if whatever acts as a choke on your engine has failed. Most common would be a coolant temp sensor, cold start injector, or very likely a moisture related issue, such as bad plug wires,cracked distributor cap, etc.
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
1helpful
How to have cityville cash?
In order to get city cash for the game Cityville you will need to purchase it online. Here's how
  1. When playing Cityville click the "add coins and cash" tab under city finances.
  2. Follow the games simple walk through on completing your purchase.
City Cash Pricing (USD) - 15 CC for $2.24
- 40 CC for $5.60
- 75 CC for $10,08
- 170 CC for $21.28
- 465 CC for $54.88
- 1,000 CC for $110,88
Top Pokemon Video Game Consoles & Games Experts
NOEL
NOEL
Aron
Are you a Pokemon Video Game Console and Game Expert? Answer questions, earn points and help others
