Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Weed easter just stopped running and will not start. Was doing great, has gas, plug loks ok--need help?
  • 1,511 Answers
Weed EASTER? Plug LOKS? Need help spelling!
First off, if the gas/oil combo is aged, that can cause problems. Use fresh fuel. Second, Steven; check for Water in the fuel or dirt in the lines. You may have to disassemble the entire head and clean the parts. You may need a new Seal to prevent oil/gas leaks, so be prepared.
Posted on May 10, 2014
  • Dayton Computer
    Dayton Computer May 17, 2014
    Did the answer help any, or did you forget about our advice?
  • 718 Answers
First check to see if your fuel line inside tank did not fall off along with the clunk.
Posted on May 15, 2014
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Get a glass jar pour the gas in it you might need more than one jar
water sinks to the bottom see any if yes make sure all old gas is out if there is water check the can you have your gas in it might have water in it clean it out or get new one. now get a pair of hemostats and fish out the line with the filter, pull filter out of tank get a new one, or like me let it dry in the sun see if you can blow through it if you can put it on, or a new back on remove air filter get starting fluid give it a small shot in the carb open choke if it starts and dies give it another go, helps to have a friend spray starting fluid in it if it starts to die. if that don't work you may need carb cleaned out if you know how if not go to you tube and find a video good luck y'all !
Posted on Jul 13, 2014
MY TROYBILT TB22 WEED EATER WILL START AND RUN FOR ABOUT 5 SECONDS AND THEN STOP
Hi did u get the coil checked it's possible it's breaking down under ( LOAD ) any good mower shop will put it on there tester ...cheers
May 17, 2018 | Garden
I got a Tory Bilt weed eater the Model-TB2OCS and I just put in new fuel linds and a new fuelter.
Verify that the new gas lines are on the carb correctly and the bulb is holding gas. If that is ok then the carb is needing to be rebuilt because one of the jets is plugged up or both. If you pour gas in the carb and it starts and runs for a short time then the carb is probably the problem. You can buy a rebuilt kit for them cheap.
May 21, 2017 | Garden
Weed eater runs fine till I tilt it down to start trimming then it dies??
Check the gas line that is in the fuel tank . It has a filter on it and if its not down at the bottom of the tank where it should be then its not getting the gas it needs. If you tip it the gas may be too low for the hose to pick up. The hose needs to be on the bottom.
Jul 14, 2016 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weed eater won't run
Sounds like you may just have a dirty carburetor.
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jul 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
109 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
