Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
Adjusting valves kohler courage 19 - Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
3 Suggested Answers
  • 4345 Answers
SOURCE: i have a 19 hp kohler courage on my toro zero turn
This sounds like the carb is plugged. Sometimes fuel thickens and makes globs...
If you verified the fuel flow to the inlet of the carb, then you need to take the carb off and open it up....
So, what needs to happen is you blow out all of the passageways with carb cleaner.
Any adjustable jets: make note of the position it is in, and FINGER TIGHT turn it clockwise until it closes (typically 1 to 1 1/2 turns) SOOOOO, you can set this jet back to the same positon....when finished blowing everything out, bottom the jet and back out the number of turns out, noted for that jet.
Open the float chamber, and clean as necessary, Inspect the float adjustment: invert the carb, and observe the angle of the float, relative to the carb body.... Usually almost parallel, but not necessarily.
Inspect the inlet valve, and clean those areas...
I usually use all new gaskets and valves, but if you are not a carb person, cleaning is effective and I think old gaskets may be okay, if not torn or damaged.
Posted on Mar 11, 2011
dwls69
  • 6 Answers
SOURCE: do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Posted on Apr 15, 2012
How to adjustvalves on kohler22 on craftsman
Gary, they may be hydraulic and not require adjustment, check the attached links, they will help determine and show how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
How to Adjust the Valves or Valve Lash on Kohler Courage XT Lawn Mower...
Work on the Cub Cadet i1046 Kohler twin setting the valves
Owners Service Manuals
Apr 14, 2016 | Cars & Trucks
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
One side move fine the other moves only when engaged slightly
may need an adjustment for the controls some mowers will do this at a slow idle if its hydrolic
Aug 18, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Fuel keeps coming out of the carb
replace the needle valve in the carb the fuel we get now melts the seal off the valve then change the oil
May 20, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do you not know how to reset governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a 19 hp kohler courage on my toro zero turn mower. it wont start. i sprayed fuel into carb and it started but as soon as it was burned it died. I checked fuel pump and it was working good. i checked...
Mar 11, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
20 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
