Question about Bladez Exercise & Fitness
Bladez fitness prisma supra error code E03 what does this mean
What does error code mean e03 on bladez fitness prisma supra
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: lifespan fitness focus treadmill E03 error
repair the magnet wire, adjust the magnet and reset see the diagram attached.Clean it.
5_6_2012_11_28_07_am.gifsincerely. God bless you
Posted on May 06, 2012
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
WHAT DOES E03 ERROR CODE MEAN?
Seems it means the SD card may be full, missing or otherwise unusable
Nov 22, 2013 | PANDIGITAL Office Equipment & Supplies
E03 and E02
The error e03 is associated with a speed issue. Most likely a misaligned sensor which is a small black cylindrical piece about 1.5" long and will have a cord that runs from the lower board around the frame and points to the front drive pulley. It should be about 1-2 credit card widths away. Also check that the round magnet is still located in the front pulley. On most units an LED will light up on the LCB (lower control board) as the magnet passes the sensor. If your handy enough to check continuity then look for an open/closed signal as that magnet passes. If this all checks out then very likely you have an LCB issue. You can however also check the motor brushes and run the motor separate which is another topic
www.FitFix.ca - Jamie Miller FitFix Inc Fitness equipment sales service and repairs
Nov 10, 2013 | Bladez Fitness Prisma Supra Folding...
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
Canon printer mp495 error code e03
* E03 error means that it may have something to with a clogging of the paper feed sensor.
try to clean every theing in the paper path and check if there is no sensor broken or bend or stuck
Nov 10, 2011 | Office Equipment & Supplies
Getting error code E03-40. What does this mean?
E03-40 - faulty toner density sensor try the following press function the original size then 3..... your screen should display f1 service mode then press 8 then start now you should see f8 ..... now press start and scroll down to option 09 and press start now you wait till machine runs the process... after that you need to switch the machine off wait 1 minute and switch it back on
Jun 04, 2010 | Panasonic Workio DP-3520 Copier
Dp 4520 error code E03-60
error e03-60 means waste toner collection. could be a problem with the mechanism that delivers the toner to the waste bottle. looks arround there
Oct 09, 2008 | Panasonic Workio DP-4530 Copier
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Exercise & Fitness Logo
42 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
qa1012
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
