Question about Cameras
Praktica instructions Trouble getting dcz 7.4 to come on
  • 1,511 Answers
This needs a professional camera service advisor in your area to observe, test, and repair.
Posted on May 10, 2014
SOURCE: praktica DCZ 3.2 D transfer pics to card
just phoned the praktica company and you cant download from camera to memory card you need a usb lead which they supply at £10.00 cheque or postal order
Posted on Jan 15, 2009
BillB-SA
  • 2761 Answers
SOURCE: praktica dcz 8lm camera: when turned on the light
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 15, 2009
fikretunalir
  • 238 Answers
SOURCE: praktica dcz instruction manual
0e94afd.jpg May be this will help a little bit. Manual can not be found.
Posted on Feb 25, 2010
lock123
  • 6831 Answers
SOURCE: Hi My PRAKTICA DCZ 520 camera is saying CARD
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
lock123
  • 6831 Answers
SOURCE: I CANNOT FIND THE INSTRUCTION MANUAL FOR THE
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Posted on Sep 29, 2010
Where can I get a lead from praktica dcz 1.4 1to transfer pictures to computer
Hi, you need this cable:
http://www.gumtree.com/p/for-sale/usb-to-mini-b-cable/1092659268
Dec 26, 2014 | Praktica DCZ Cameras
I CANNOT FIND THE INSTRUCTION MANUAL FOR THE PRAKTICA DCZ 8LM CAMERA
Hello
Kind regards
Andrea
Sep 25, 2010 | Praktica DCZ Digital Camera
Praktica dcz instruction manual
Jan 29, 2010 | Praktica DCZ Digital Camera
Praktica DCZ 3.2 D transfer pics to card
Dec 06, 2008 | Praktica DCZ3.2S Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
