Question about Kenmore 96610 / 96611 / 96612 / 96614 / 96619 Electric Kitchen Range
My kenmore electric range model #790-96619401 does not keep a steady temperature while baking. If i set it at 325 it will go as high as 359 and as low as 277. Elerything else works. No errors. Thanks, Warren
I have a Jenn Air Electric oven and range Model S 160 (S/N 149102TU). One burners on the RT. goes to ''High'' regardless of the knob setting. ...
Posted on Jan 03, 2010
    President:
  • 744 Answers
Sounds like a temp sensor to mesensor will noormally run from control panel through the cooktop into the oven..you might try replacing it.
Posted on Jun 23, 2009
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
How to fix temperature sensor in wall oven
Your error is an overheat error. Odds are that the control board is shot, either the electronics controlling the relay are bad or the contacts of the relay are welded together.
What is your model number?
Jan 05, 2014 | Kenmore 96342 / 96344 / 96349 Electric...
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Kenmore 96610 / 96611 / 96612 / 96614 / 96619 Electric Kitchen Range Logo
701 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
