Question about Bladez Fitness Exercise & Fitness
What does this error code mean e03 bladez fitness treadmill prisma supra a wing systems s#4012457
Djmonier75@yahoo.com and where can I find a manual for this unit
  • djmonier75 May 12, 2014
    so far i have taken the cover off the treadmill discovered that the fan for the motor was broken broke down the dc motor checked brushes and springs pulled communtator out cleaned noticed winding wires are purple looking that is the only thing that bothers me i think windings should be gold maybe the motor got to hot but i would still like to know what e03 means to make sure i am going in the right direction with this as far as the booard you hit start it counts down you can here the relay kick for motor to turn on but the motor does not kick on hten you hear relay kickout and e03 pops up on the screen
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
outfield502
  • 79 Answers
SOURCE: How do I download a manual for a Spirit Fitness Z500 Treadmill
http://www.spiritfitness.com/ownersmanuals.asp just keep it in a folder and go!
Posted on Feb 09, 2010
maxtreadmill
  • 832 Answers
SOURCE: Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
Posted on May 06, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
  • 42 Answers
SOURCE: Whats up with the P350
BH Fitness
P350 Treadmill
hi this is the best i can find, also make sure they give a full gurantee, these treadmills are not that good, if your looking for something more better try a weslo candence m6 new from 400
r20" x 50" Running Belt
  • Folds up for Space Saving
  • Safe Drop Lowering Feature
  • Large Blue Backlit LCD w/ Dot Matrix Allow More Information at the Same Time
  • 2.25 Continuous HP Drive Motor
  • 9 Built in Programs
  • Quick Speed and Incline Keys
  • Personal Cooling Fan
  • Contact Heart Rate Sensors
  • 325 Pound Max User Weight Capacity
  • 10 Mph & 13% Grade
Posted on Nov 21, 2010
What's the error code e03 mean on the pro fitness motorised treadmill
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 01, 2017 | Exercise & Fitness
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
E03 and E02
The error e03 is associated with a speed issue. Most likely a misaligned sensor which is a small black cylindrical piece about 1.5" long and will have a cord that runs from the lower board around the frame and points to the front drive pulley. It should be about 1-2 credit card widths away. Also check that the round magnet is still located in the front pulley. On most units an LED will light up on the LCB (lower control board) as the magnet passes the sensor. If your handy enough to check continuity then look for an open/closed signal as that magnet passes. If this all checks out then very likely you have an LCB issue. You can however also check the motor brushes and run the motor separate which is another topic
www.FitFix.ca - Jamie Miller FitFix Inc Fitness equipment sales service and repairs
Nov 10, 2013 | Bladez Fitness Prisma Supra Folding...
Bladez prisma treadmill error e1 replaced lower control board and speed sensor
I will answer my own problem here, maybe it will help someone else. After BH North America customer service told me I needed a new lower control board and I had to spend $100+, it wasn't the board. Then they said it was the speed sensor, they sent that out for free, that wasn't it. Now, they would not respond to me. So, we went off the troubleshooting guide saying it was a connection problem between the upper and lower board. My husband opened up the "leg" of the treadmill and checked the connections (cutting the tie cords that hold the wires tightly in place, maybe too tightly and that's what caused them to come unplugged) and now the belt runs! So, BH got another 100 dollars of my money, on top of the original $800 and solved nothing and then ignored my emails. Horrible customer service and when this one finally bites the dust, I will never purchase a machine from them again. P.S. This treadmill is only approx. 2 yrs old.
Feb 12, 2013 | Bladez Fitness Prisma Supra Folding...
Lifespan fitness focus treadmill E03 error
repair the magnet wire, adjust the magnet and reset see the diagram attached.Clean it.
5_6_2012_11_28_07_am.gifsincerely. God bless you
Apr 21, 2012 | Exercise & Fitness
Instruction manual
Hi, please can anyone help. Looking for owners manual/user guide for a BH FITNESS PIONEER PRO (PART NO G6448N) Treadmill,
Please email me ell-jay@hotmail.com
Thanks
Aug 08, 2011 | Bladez Fitness BH T8 PRO Treadmill...
Exercise & Fitness Logo
Top Bladez Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Bladez Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
