Question about PC Chips M981G Motherboard
OPERATING SYSTEM The run command was corrupted
  • 656 Answers
If u are using XP insrt ur cd and boot with xp cd then run repair type in fixmbr 2 step fix boot i think it will rectify ur problem or run full repair of ur os
Posted on Nov 29, 2007
Error code Ox80092003 on vista pc
Run System File Checker (SFC) to check if Windows Vista system files are corrupted.
1. Click Start, type "cmd" (without the quote) in the Start Search bar, right-click cmd.exe and click run as administrator.
2. Input the following commands and press Enter after each line.
sfc /scannow
Note: There is a SPACE between "SFC" and "/Scannow". This command will take several minutes to complete.
Restart the computer.
Sep 11, 2013 | Microsoft VISTA Computers & Internet
Os my be corrupt what can i do to get it back
What makes you think it is corrupt? What are you doing and what messages occur to make you think that?
Will it boot up successfully when you press the power button? If not, it might just be a missing or corrupt boot or system file.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If the operating system is indeed corrupt, then you will need an operating system disk to reinstall it. Or you will have to to a System Recovery which deletes everything and takes your system back to when your first purchased it.
May 16, 2012 | Computers & Internet
When i start my computer a message came that 'disk
No your operating sytem or boot files have a problem. Something is missing or corrupt in the operating system or boot files.
Try the steps below.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
May 11, 2012 | Compaq Computers & Internet
I can use my Dell OptiPlex GX280 PC Desktop says that windows could not start because the following files is missing or corrupt: \windows\system32\config\system
You'll need a operating system disk or repair disk to run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | Dell OptiPlex GX280 PC Desktop
Disk error
Use operating system disk and run the command: chkdsk /r
This will run for an hour or more but it will repair any boot and system files that are corrupt or missing.
Mar 10, 2012 | Toshiba Tecra 8200 Notebook
C omputer won't re boot, it stays in DOS, command line says hit F1 but nothing happens and the command appears again.
This is what usually happens when your operating system is corrupt. See,it is failing to boot because the files responsible for boot are corrupt. The solution is to have the operating system reinstalled.
Oct 21, 2010 | Computers & Internet
User profile service failed the login user profile cannot be loaded tried restore to earllier date, changed password
The operating system is corrupted. may need to do a re-installation or Operating system repair. If you mange to get Command mode on the run a check disk
Jun 09, 2010 | Compaq Presario 5000 PC Desktop
My Network Places applet keeps disappearing and reappearing
It sounds very much like the operating system file have become corrupt.
Click on the the start menu and click on run. When the run box pops up type cmd and hit enter.
A command line window will pop up, in the window type sfc /scannow (leave a space between the c and / ) and hit enter. The system will now check for corrupt operating system files.
When its done (and this could take some time) check to see if the problem has been resolved. If it's fixed then job done but if not please post back and I'll give you another command to check the the disk itself.
Good luck.
Jan 11, 2010 | Microsoft Windows XP Professional SP2
Problem with satellite a85 wireless and dvd not working
Hello
If bothe of these problems occurred relatively close together then I would say you've been infected. Run AVGFREE, MALWARE BYTES and SUPERANTISPYWARE. Once the operating system is clean, then goto Start, Run and type SFC /scannow. This commands will put back drivers that were corrupted. Be sure to have the orginal Operating System CD at hand.
Jul 30, 2009 | Toshiba Satellite A135-S2276 Notebook
Setup cannot find C:\WINDOWS\COMMAND.COM
the windows command interpiter is probally causing the problem. you have a corrupted operating system. you have two options, one is to replace the file and rename the old file from a pc running the same os. the other would be format and reinstall the os or restore disc.
Jul 12, 2009 | Microsoft Computers & Internet
PC Chips M981G Motherboard Logo
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
