While driving to work yesterday, my 06 PT Cruiser simply stalled , all dash/dummy lights came on and had slight hesitation and then just continued on. no problem restarting next day no problems as of yet. Also took to connect at autozone to diagnostic no codes poped up - would really appreciate any help or advice - Thanks
SOURCE: 06 PT Cruiser - Stalling - Rough Idle
HI;
I AM A CHRYSLER PARTS/SERVICE MANAGER AND HAVE SEEN THESE TURBOS BLOW INTAKE TO PLENUM GASKETS. WE ARE A SMALL DEALER AND HAVE SEEN 3 HAPPEN AND ALSO WAS VERY DIFFICULT TO DIAGNOSE. WE WERE ABOUT TO PULL THE HEAD ON ONE WHEN WE FOUND THE GASKET SUCKED IN. PART IS CHEAP AND REPAIR NOT TERRIBLE .HAVE YOUR TECH SPRAY CLEANER AROUND SEAM BETWEEN INTAKE AND PLENUM ENGINE SHOULD DIE DOWN WHEN YOU HIT THE LEAK
SOURCE: i have a 06 pt cruiser the battery light came on
there is a tsb on that in the dealerships i belive there is a flsh for the computer to fix this problem i have been a mechanic at a chrysler dealership for 9 years now and that is a pretty common problem
SOURCE: 02 PT Cruiser LE w' Code P0340
My thought is to get a refund from the shop that tried to replace parts in order to secure your problem. The job of the shop is to diagnose the problem, not to replace items that may be the problem. Chrysler Master Techs are not trained to just replace parts, they fix the problem by diagnosing it properly.
You need to see a Chrysler dealership so they can attach a DRBIII and tell you exactly what is at stake.
I hope this helps you. I would be mad as heck.
I would not think the plugs and wires would be the problem because they would all have to fail at the same time to provide the symptom you experienced.
1. Get your money back
2. DRBIII
SOURCE: DIAGNOSTIC code P01A4 for pt cruiser
I have the same problem. Pt - 2002, 2.2 diesel. Same mistake number appeared. Noone knows what is it.
SOURCE: My PT Cruiser (2002) runs for 5 min., then
P1391(M) Intermittent Loss of CMP or CKP Loss of the Cam Position Sensor or Crank Position sensor has occurredi know that you may not want to take this to a good mechanic, but it may be something simple, or it could be bad.
