Question about Krups 240 Watts 8008 3 Mix Combi Hand/Stand Mixer
Krups ka950 food mixer no speed control always top speed
  • 1,511 Answers
The speed selector circuit has been compromised but either an electrical short, or disruption from particles that entered the switching mechanism and covered contacts. Needs technical attention.
Posted on May 10, 2014
  • grahoward May 10, 2014
    Thanks very much for your time and answer.
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: I was given a Krups
The truth is that the user manual for your
Krups stand-portable mixer is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the user manual from them. They might give it to you or direct you to a dealer where you can get the user manual.
This is the best you can do to get the user manual you are requesting for.
Go to krups' website (http://www.krups.com/Home.htm), check "Contact Us" and you would see their e-mail and phone number.
Or just go straight to; http://www.krups.com/Tools/Contact/Contact.htm
Select your country......
I hope you understand the above.
Good luck.
Posted on Feb 15, 2011
My mixer will only work on high speed why
Speed controllers reduce the power provided to the mixer motor and have to "soak up" some of the power not used. If the mixer was used on low speed but heavy load, it could have burned out the speed controller. Some of them fail by shorting out which means that the motor always gets full power regardless of speed setting. It sounds like your speed controller has burned out.
Feb 19, 2017 | Food Mixers
KitchenAid mixer runs at full speed only
It is most likely the phase board which is the little PCB under the back cover at the top, it has 4 wires coming out of it that plug into the black speed control board.
Mar 05, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer speed
If it has suddenly got high speed all the time and the two adjustment screws at the top of the speed control board are not loose and have not been messed about with the most likely solution will be to replace the phase board. That's the little PCB just above the speed control board with the 6 wires coming out of it.
Nov 23, 2013 | Food Mixers
SPEED CONTROL ALWAYS ON HIGH
Speed control plate at the back is stuck in the high position or you need a new phase board. That's the small PCB under the back cover at the top.
Nov 24, 2012 | KitchenAid K5SS Heavy Duty Commercial...
How can I service an A901 kenwood mixer, need to get top plate off.
the speed control on my kenwood chef A901 is not working
how do i fix this.
Oct 16, 2012 | Kenwood Chef Major A701 A901 Cm170 Km201...
Speed control swich on Kenwood Titanium mixer
The switch on the titanium has a flimsy week point and is always breaking. This is a stupid economy by Kenwood when there is now so much good competition. Mine broke after only 6 months and Kenwood were less than helpful suggesting I took back to where I bought it - 500 miles away!! I wish I had bought a Kitchen Aid
Jul 08, 2012 | Kenwood Food Mixers
Kitchenaid KSM150 stir and slow speeds are running too fast why is this?I just got this machine, its brand new from ebay (america)
It sounds like the speed control plate is not correctly adjusted. If you take the back cover off of the mixer (it is held in place with a screw at the top) and try adjusting the screws on the back plate you may be able to get the mixer to slow down.
You will notice two screws at the top of the speed control plate:
4893809-mz0mnwb1nd52ertzwibinpxu-3-0.jpg If you turn the top screws one quarter turn, both equally then test the mixer it should adjust the speed. Please make sure not to over tighten or loosen these screws as it can damage the speed control plate! You should not have to mess with any wires attached to the speed control plate or the bottom screw.
If you need more information please see the service manual here: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
It will specifically go over how to trouble shoot the mixer and how to adjust the speed control plate.
Please let me know if you have any questions
-Colleen @Mending Shed
May 22, 2010 | KitchenAid KSM150PS Artisan Series Stand...
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
Krups 240 Watts 8008 3 Mix Combi Hand/Stand Mixer Logo
91 people viewed this question
Top Krups Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Krups Food Mixer Expert? Answer questions, earn points and help others
