Question about Bladez Fitness Prisma Supra Folding Treadmill Exercise Home Gym Equipment
What does this mean and how do i fix bladez prisma treadmill error e03 code
Email is djmonier75@yahoo.com
What's the error code e03 mean on the pro fitness motorised treadmill
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 01, 2017 | Exercise & Fitness
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
E03 and E02
The error e03 is associated with a speed issue. Most likely a misaligned sensor which is a small black cylindrical piece about 1.5" long and will have a cord that runs from the lower board around the frame and points to the front drive pulley. It should be about 1-2 credit card widths away. Also check that the round magnet is still located in the front pulley. On most units an LED will light up on the LCB (lower control board) as the magnet passes the sensor. If your handy enough to check continuity then look for an open/closed signal as that magnet passes. If this all checks out then very likely you have an LCB issue. You can however also check the motor brushes and run the motor separate which is another topic
www.FitFix.ca - Jamie Miller FitFix Inc Fitness equipment sales service and repairs
Nov 10, 2013 | Bladez Fitness Prisma Supra Folding...
Carl lewis mot566 treadmill error code e03
please adjust the REED switch, see the diagram attached. Clean it +test it for open or faulty+tight the connector very well.
However if the problem persist error code 3, this is a problem with the PCA memory location, RAM. the solution is to replace the PCA.
Try to RUN the software calibration for easy diagnostic, and fix it
God bless you
Jun 22, 2013 | Exercise & Fitness
What does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Apr 03, 2013 | Exercise & Fitness
Bladez prisma treadmill error e1 replaced lower control board and speed sensor
I will answer my own problem here, maybe it will help someone else. After BH North America customer service told me I needed a new lower control board and I had to spend $100+, it wasn't the board. Then they said it was the speed sensor, they sent that out for free, that wasn't it. Now, they would not respond to me. So, we went off the troubleshooting guide saying it was a connection problem between the upper and lower board. My husband opened up the "leg" of the treadmill and checked the connections (cutting the tie cords that hold the wires tightly in place, maybe too tightly and that's what caused them to come unplugged) and now the belt runs! So, BH got another 100 dollars of my money, on top of the original $800 and solved nothing and then ignored my emails. Horrible customer service and when this one finally bites the dust, I will never purchase a machine from them again. P.S. This treadmill is only approx. 2 yrs old.
Feb 12, 2013 | Bladez Fitness Prisma Supra Folding...
F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
Dec 31, 2012 | Bladez Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
Bladez Fitness Prisma Supra Folding Treadmill Exercise Home Gym Equipment Logo
23 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
qa1012
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
