Question about Kenmore 500 6952 Dryer
Kenmore dryer stackable model number 41794812301
How to change the belt
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
  • 17 Answers
SOURCE: dryer spins but does not dry clothes
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Posted on Jun 09, 2009
  • 4088 Answers
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Posted on Aug 24, 2009
Jahn27
  • 1554 Answers
SOURCE: how to change the belt in the kenmore dryer model
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
Posted on May 29, 2010
Hi is it pretty simple to replace parts like BELTS. or. AXELS pulleys on a Kenmore stacked washer/dryer? and are there any TUTORIALS TOU CPULD RECCOMEND FoR DIY need fix dryer belt axel possible
YOU CAN FIND EASY HELP ON GOOGLE OR YOUTUBE , JUST WRITE FIX CHANGE BELT ON STACKABLE DRYER ETC
USUALLY U HAVE TO REMOVE THE TOP PANEL THEN THE BACK PANEL
Jan 02, 2017 | Kenmore Washing Machines
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Jun 09, 2009 | Kenmore 84052 Dryer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore 500 6952 Dryer Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
