Question about Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator
Vacation settings for frigidaire gallexy refrigerator
  • 1,511 Answers
When you purchased the unit it came with a complete instruction manual and guide. Thumb through your book and locate the answer there.
Posted on May 10, 2014
The digital panel spontaneouly beeps inidcating temps which is a normal to cross check,
Vacation mode is a setting to limit defrost function during long periods of disuse, the manual can tell you how to exit vacation mode. If the unit goes into vacation mode without being prompted to, then replace the main control board...
Apr 23, 2016 | Refrigerators
Frigadair top freezer thaws and is soft frozen when we come home from vacation, food is still cold 20 degrees, then while home freezer works fine?
Probably defrost timer not working properly, or the door is not closed or defrost depends on freezer door opening?
Appliance parts websites usually are very helpful.
Apr 02, 2015 | Frigidaire Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 21, 2011 | Frigidaire Washing Machines
Returned from vacation and can't get the ice maker to restart. It was working fine before vacation. I emptied the bin and clean it and put the refrigerator on vacation. When I returned the ice maker...
ice maker only works if tempt is cold enough . 15 deg of colder . ck the fans and ck the coil /to see if clean these are very common maintaince problems that cause your problem .. mm
Aug 17, 2010 | KitchenAid Superba Architect KSCS25INSS...
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Refrigerator settings
what is the coldest number in the setting of refrigerator and freezer
Jan 28, 2009 | Frigidaire FRS26RLECS Side by Side...
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Dec 13, 2008 | Samsung SRS20DTD Side by Side Refrigerator
Water is not coming through.
try filling the new filter up with water before you put it in probably air in system try this unless you have already hope it helps glenn.........
Nov 18, 2008 | Frigidaire FSC23F7D Side by Side...
Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
