Question about Jensen VM9510 Car DVD Player
Why dont i have a picture in my headrest monitors
I have a blue screen on my monitors but no picture. I disconnect the jacks and there is no power. Then reconnect the jacks and there is still a blue screen, but no picture.
    Problem Solver:
  • 5 Answers
Are you hooked on the right output from the indash??
do your headrests have more than one input option??
or do they ever just say "no signal"
check that out maybe something got overlooked
Posted on Jun 23, 2009
Small rectangle in the middle of the screen with the letter i in the left corner, the buttons are lockeder la hello 17
If the picture disappears from the screen and the
1 (power) indicator is green
Turn off the 1 (power) switch and disconnect the
video signal cables from the monitor.
Turn the monitor on by pressing the 1 (power)
switch.
If all four color bars appear (white, red, green, blue), the monitor
is working properly. Reconnect the video signal cables and check
the condition of your computer(s).
If the color bars do not appear, there is a potential monitor failure.
Inform your authorized Sony dealer of the monitor's condition.
Be sure to note the model name and serial number of your
monitor. Also note the make and model of your computer and
graphics board.
Mar 18, 2014 | Sony SDM-HS75 17" LCD Monitor
Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Only says cable disconnected on screen
May be your monitor cable has been faulty.You can check it from service center.
Mar 24, 2010 | Dell E551 15" CRT Monitor
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
Same monitor, same problem!!!
While the unit is attempting to "come ready", disconnect and reconnect the 7 wire blue plug. Some how or another, this disrupts the start up pattern that is failing, and the monitor comes on as normal when reconnected???
Oct 01, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Computer power button for the monitor blinks blue
there are two reasons for this to happen there are blown capacitors inside the monitor and or there transistors on the board that have failed. both can be repaired.
Feb 25, 2009 | Proview PL926WBi 19" LCD Monitor
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Jensen VM9510 Car DVD Player Logo
299 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
