Question about managemylife.com
Kenmore washer. Water drained while sitting how to restart
Kenmore washer. Manual says "if lid is left open for more than 10 minutes, the water will pump out automatically". How do I restart it? There are no lights and it only hums...maybe still draining some water. But no spin
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
You could try and unplug it for a bit to see if it will reset itself
Posted on May 10, 2014
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
What does the code PO mean?
Hi, PO means Pump Out (lid opened).
Po flashes when drain pump begins pumping out water from tub upon activation by the door lid having been left open for more than 10 minutes.Close door lid to stop drain pump.
Oct 04, 2010 | Whirlpool WTW6400SW Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Kenmore washer want go thru spin cycle
If it sits there with water and doesn't drain or spin, it thinks the lid is open. Try depressing the lid switch and see if you hear a click. Try replacing the lid switch.
Sep 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Kenmore elite washer cycle signal keeps going off an on turing cy
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2009 | Kenmore Washing Machines
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Jul 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Won't spin/agitate and change cycles
If your washer fills and does not agitate or spin, it could be a simple lid switch problem. That's also probably the reason why it won't drain, either. Switching load sizes activates the pressure switch, which controls the level of the water in the tub (this is normal).
Locate the lid switch. It should be located on the right-hand side of the tub rim. There's a small hole in the rim where a small peg (called a lid strike) inserts from the washer lid to activate the switch. Check to see if the lid strike is not broken off. If the lid strike is still attached, open and close the lid to see if you can hear the switch "clicking". If no clicking noise is heard, take a small screwdriver and push it down through the opening to see if you can activate the switch (leave the timer knob pulled out when you do this to see if the washer starts). Double check the mounting screws to ensure they are tight. Sometimes the screws will come loose and the switch will not make contact with the lid strike.
Now some washers have the lid switch located on the left-hand side UNDER the washer rim by the lid hinge. This type of switch is activated by a rod on the lid hinge and fits into an opening in switch. Usually, this type of switch only requires an adjustment of the rod to correct any problems.
Please post back with your model number, so I can make sure what type of switch you have.
If you diagnose the problem and need to replace the lid switch, just click on the link below for complete step-by-step instructions.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I hope you find this information helpful. Let me know if you have further questions.
PS You do not have to drain the washer to replace the switch. If you need to drain it, however, post back and I can tell you how to bypass the lid switch to get the washer running to drain.
May 13, 2008 | Kenmore 24032\24036 Top Load Washer
managemylife.com Logo
74 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
