Question about Ovens
Creda oven manual
I have a Creda Europa Solar Plus oven 48145(1 upper oven/Grill plus 1 fan assisted oven below). Over a period of time the grill has partially stopped working and it seems to take forever to cook anything. No 6 cooks like no 6 (full power) but all other setting the grill is hardly ever on. Can you advise what could be wrong and if it is something I can fix myself? If so are the parts still available?
  • 742 Answers
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on May 10, 2014
  • Jon Doling
    Jon Doling May 10, 2014
    Do you know what the part is? is it the thermostat or regulator?
  • Daryl Gleaton May 11, 2014
    The heat control switch for the burner. You can type Creda Europa Solar Plus oven 48145 into your Google browser and there you can locate parts, schematics and repair manuals. Hope this helps. The burner control (rheostat) controls the current to the burner. If you have a local appliance dealer they can test the burner and the switch for you.
SOURCE: re creda europa solar plus no insrustions for cloak/timer
Look here, it is a different model, but the clock is the same
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HB48904_489000069-05.pdf
Posted on Jun 22, 2009
  • 157 Answers
SOURCE: I need a new element for my Creda fan oven but
what do you want model creda concept 46307
Posted on Mar 09, 2010
barkencoa
  • 3463 Answers
SOURCE: Hi.I have a creda europa
You need to replace the fan oven element located at the rear of the oven compartment behind removeable cover.
Posted on Sep 24, 2010
SOURCE: creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Posted on Sep 26, 2010
noranda21
  • 1547 Answers
SOURCE: Creda Europa Oven an Grill Big oven has Stopped
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Posted on Dec 05, 2010
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Creda europa solar plus double oven
Dec 02, 2008 | Ovens
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Ovens Logo
247 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
