Question about Hitachi 50UX57B 50" Rear Projection Television
2 inches of picture from top is brighter and picture in tthat area is distorted
I have an intermittent problem that presents itself most of the time. The part of the screen that covers 2-3 inches from top is brighter. The picture in that area is distorted specially close to the junction of the normal portion and the lighter portion. The rest of the screen is okay.
Is this expensive to fix?
  • 979 Answers
Hmmm, could be anything from dirty optics, to a convergence problem....accordianman
Posted on Feb 18, 2008
The dark areas of a picture is red
the screen itself is going bad and wearing out . there is no repair except replacement of the tv .
the screens are so expensive to buy there would be no point
sorry i could not bring you better news
Feb 02, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
I have an HP 2009m monitor. When I try to have
The problem is that your picture is not of high enough resolution. You need to get a higher resolution picture. There is nothing wrong with the monitor. The picture is distorted because the picture does not contain enough photographic data to scale to the size you are stretching it to. Higher resolution = larger picture without distortion.
Jan 03, 2010 | HP 2009M Monitor
Picture Problem
This is a problem (one of several) caused by poor solder connections on the circuit board. RCA uses the metal shield can surrounding the tuner circuitry (the area where the cable connector is located) to provide several ground connections. Many of these connections go bad (cracks form) and the missing ground connections cause the "picture shrinking" you see. Other problems are loss of tuning, set that intermittently turns off or on by itself, set that won't turn on at all, and even more.
The repair involves removing the circuit board and flipping it over so you can remove a metal cover on the bottom, repairing the several (many) affected connections, and then reassembling. This is a relatively easy repair for someone with soldering experience and the right tools (both a high-heat soldering gun and a low-heat iron are needed). But because of the fragile circuit traces in the repair area it is possible to do more harm than good if you don't know what you're doing.
RCA produced a service bulletin several years back detailing the areas to be repaired (although they still refused to admit they just hadn't soldered the places adequately to begin with). I'm not home now so I can't check my files but I'll see if I can find a link and add a comment later. When I was in the service business we charged around $60 for the repair. You might want to get an estimate from a shop (they should already be familiar with this trouble). Or if you're looking for a reason to buy a new set, try the repair yourself. If you're successful you've saved yourself the money. If not, it wasn't working anyway!
Feb 02, 2009 | RCA F25441 25" TV
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Picture beginning to fail
Jul 13, 2008 | Televison & Video
32Inch Flat Screen SDTV - with picture distortion
If you have a TV shop at all any more in your area, any tech working on them will know where to look. This is a pretty common problem although you are getting it too early.
Since it will require a certain type of instrument (capacitance meter) to verify the problem part, I don't want to go into detail concerning a 'do-it-yourself' repair since it may be a little difficult to order these in single quantities and a decent shop should have the right value on hand.
It shouldn't cost too much.
Jun 28, 2008 | Philips 30PW633R 32" TV
There are some components it the vertical deflection amplifier area that are becoming thermo sensitive with age. It is also possible that there will be parts going off value in the power supply and other areas.
These problems are typical in these sets when they are aged. The cost of the repair may not be worth the investment.
You should take the set in to a service center for an estimate.
Jerry G.
Jun 12, 2008 | Philips Magnavox 20MS233S 20" TV
Samsung 42" rear projection tv. Picture is slightly distorted at top left hand corner. All three bulbs seem okay and the mirror also seems fine. It's as if there is an issue before the bulbs. Any...
What's the model number? Describe the distortion in some detail. Is it intermittent? Does it seem to affect anything else, like audio, when it's present?
Apr 09, 2008 | Televison & Video
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Hitachi 50UX57B 50" Rear Projection Television Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
