Question about GE JGSP48SHSS Gas Kitchen Range
How do I remove the front panel to get at the Oven Control?
I've removed all the screws, but panel will not budge.
  • 1,511 Answers
The top has pins that need to be separated from the body by lifting up with your fingers at the edges of the frame. Use caution with devices like a screw drive that can be used, but may chip pait or surface protection.
Posted on May 10, 2014
3 Suggested Answers
SOURCE: GE model JKP13GOP2BG control panel faulty ( F1 code)
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
Posted on Dec 13, 2008
mgprice
  • 744 Answers
SOURCE: Trying to remove oven element. I removed screws,
Hi, it would be easier for a novice just to simply pull the unit out from the wall and remove the lower panel at the back. Behind this panel you will expose the terminals for the heater. Remove the terminals (wires) and then go round the front and take the screws out. Next pull on the heater and it should slide out. If you have any other questions please feel free to ask. Mike
Posted on Mar 25, 2010
How do I remove the front control panel on a ge profile je2160sf01?
On most over the range ovens, the screws for the control panel are on the top of the control panel. You usually have to remove the air deflector above it to acccess the screws.
Dec 24, 2016 | GE Microwave Ovens
Oven keeps blowing thermal fuse
  • Disconnect the oven's power supply by turning off the breaker in your home's service panel.
  • 2 Open the lower oven door. Remove the screw at the bottom of the trip panel on each side of the oven.
  • 3 Pull the trim away from the oven approximately 2 inches, then slide the trim panel down to remove it from the oven.
  • 4 Remove the screws from the bottom sides of the control panel.
  • 5 Pull the control panel out from the bottom, then lift the panel to remove it from the front of the oven.
  • 6 Detach the wire connectors from the control panel by depressing the tab on each connector and removing it from the control panel.
  • 7 Depress the tabs on the thermal fuse wire connectors, then remove the thermal fuse.
  • 8 Attach the wire connectors to the new thermal fuse to install it in the control panel.
  • 9 Reassemble the oven by reversing the steps used to take it apart.
  • 10 Restore power to the oven.
Jan 21, 2014 | managemylife.com
How do i remove the front panel from the whirlpool accubake double oven
1. You need to pull the oven out a few inches to be able to access two screws on each side of the control panel. On my oven, I needed to open the lower oven and remove a screw from each side to allow a vertical cover piece to be removed. With those pieces removed, there were two screws on each side that went into the wood frame around the oven. I also had a screw on the bottom of the oven, but it didn't not look standard. With those screws removed, the oven pulled out fairly easy. Just need to pull out far enough so that the two screws on the control panel assembly are accessible.
2. Remove those two screws and the panel can slide out once a number of cables have been removed. I took a picture of the connections before removing so I was sure I would put them back correctly (see below). The ribbon cable comes off by raising the plastic piece on top of the connector.
I replaced my panel with a Sears part that had been rebuilt. I couldn't find any new parts anywhere. It's been three weeks and, so far, my oven is working fine.
Nov 04, 2011 | Whirlpool RBD305PD Electric Double Oven
My GE JKP45 double oven needs a new control panel (part # WB27K5047 which is no longer available) There are a few place I've found on-line that refurbish electronic panels, or if it only has a loose...
according to the website i use to look up part#s while the part# you have is indeed not available a replacement for it is WB27T10050
to removeand replace it unscrew the screws that hold it to the cabinet pull it out about 4-6 inches,remove the grill directly under the control panel on the upper oven and look for screws around the panel where ya have pulled it out of the cabinet
to see yourself the replacement part# go to searspartsdirect and enter the model# and you will see the eoc (electronic oven control) as item #16 under the control panel and top tab
Jul 20, 2011 | GE JKP45 Electric Double Oven
Wall electric oven gets hotter than the tempature reading on the control dial
If this has a manual turn oven control (not electronic) you will have to replace the oven control thermostat.
First shut the power off to the oven at the main breaker. Remove the screws holding the front control panel in place. Some of the screws are located inside the oven and some are on top of the control panel. Tilt the control panel forward to access the oven thermostat. While holding the new thermostat in your hand transfer each wire the the corresponding numbers on the new thermostat. Unclip the oven sensor from inside the oven and feed it into the control panel area.Remove the screws holding the old thermostat to the control panel and discard old thermostat.
Insert new thermostat into the control panel and screw to panel.
Reinsert the thermostat sensor into the oven cavity and fasten to clips.
Re assemble control panel.
WARNING: make sure that no wires are touching when reassembling.
When everything is back together, turn power back on and test temperature.
Dec 30, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Control panel buttons due not work
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
email me for pics schmidtkeith1@yahoo.com
Aug 31, 2009 | Maytag 30" Built-In Single Electric Wall...
I have a GE profile Glass top M#JSP47COF4CC That is cracked but can't figure out haw to remove. Have already removed 4 screws under control panel still won't budge
To remove the top on this range, remove burner knobs and face plate, then remove 2 screws from control panel one at each end. Fold panel down out of the way, remove 5 screws accross front of control panel and release 2 quick connect plugs for burners, then lift to remove glass top. Flip over remove 2 screws and clips from each burner and the indicator light assembly just pops out. Transfer this to new top and reverse your steps for removal.
Mar 27, 2009 | Kitchen Ranges
Control panel disassembly
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Jul 11, 2008 | Ovens
How do I remove the front control panel?
remove the 3 screws at the rear top to remove the top cover. you now have access to back of control panel. tou should see some plastic lugs sticking out through metal clips. you will have to force the lugs through the clips with a flat blade screw driver. be careful it is easy to brake them
Feb 13, 2008 | Asko W6021 Front Load Washer
Built in GE wall oven
why are you trying to remove the panel are you talkin about the control panel
Nov 13, 2007 | GE JKP15 Electric Single Oven
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
