Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
How to shut off refrigerator and restart it at a later date
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Unplug it
Posted on May 10, 2014
My Samsung CoolTech Model SR-L709EVSS fridge and freezer works for a few days and then goes off by its self and then works again. What could the problem be?
Only time these units completely shut down is when the defrost timer shuts down all power to the compressor and condenser/evaporator motors. Only the bulb works.
If that timer gets stuck somehow that would explain the complete shutdown and mysterious restart later .
Jul 31, 2015 | Samsung Refrigerators
Why is it beeping sporadically?
It looks like it needs service of some sort. Have you referred to its manual?
May 13, 2015 | Liebherr CS1601 (15.5 cu. ft.) Bottom...
Entire cooling shut down - restarted 10 hours later, shut down again 12 hours after restarting.
Hi and welcome to FixYa, I am Kelly.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987&diagram_id=28252332#d28252332
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Kelly
Jan 19, 2011 | KitchenAid Superba Architect KSCS25INSS...
My older Frigidaire fridge does not cool things down anymore. When the cooling system tries to start, it just chokes.You hear a click and the process shuts down, but tries to restart a few minutes later....
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | Refrigerators
The refrigerator run loud for twenty minutes or so then it stops for ten minutes and starts running loud again
If the noise is coming from the back of the fridge, it could be the compressor is dying. Its cycling and over heating shutting off then trying to restart a short time after once the thermal overlaod resets. You hould call a service tech sooner than later.
Apr 04, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Certificate of Sercuity has expired
Have you tried resetting the time and date from the system tray? Double click the time on the system tray and change the time and date to what it should be!
Apr 14, 2009 | Microsoft Windows 2000 Server
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Start up problem
here after if you are getting the message means please ignore it,because once in a week that you can run the liveupdate and thats enough...
Jun 25, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
26 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
