Question about whipper snipper Garden
How toremove spool ? - whipper snipper Garden
  • 1,511 Answers
Remove the snap-on cap (Orange cap) on the bottom of the unit. Under that is a REEL (no doubt empty) and slide it out. If you have twine, rewind your own; or get fully ready to go spools and insert in the area where you remove the original. You need to Feed the new line (end) through the small hole from inside the spool area to the outer exposed portion of the whipper.
Posted on May 10, 2014
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    How to change my spool pin
    Some spool pins pull out, others have skrew threads on the bottom, yet others need to have the spool casing removed. Depends on your sewing machine.
    Search the internet for:
    Make + Model + the word "spool pin"
    or contact manufacturer support.
    Apr 21, 2016 | Brother Sewing Machines
    Toro tb65ss upper string head removal
    1. Pull the spark plug wire from the top of the spark plug. Bend the wire to the side to prevent accidental starting.
    2. Place trimmer on its side with the trimmer spool head facing you. Press the two tabs on the side of the spool head with your fingers.
    1. Hold side of the head and slowly allow the head cover to push away from the inside of the spool head. There is a spring between the spool head housing and the spool that pushes out when releasing the cover.
    1. Pll the knob and spool out of the spool head. The spring should come out on the back of the spool.
      Electric Trimmer
    1. 1 --> Unplug the Toro trimmer power cord from the electrical outlet.
    2. 2 --> Lay the trimmer on its side. Hold the spool housing tight in one hand and twist the cap counterclockwise with your fingers. If necessary, use a pair of large slip joint pliers to start turning the cap. The cap is the center piece of the spool.
    3. 3 --> Pull the cap off the spool and remove the spool from the housing.
    Apr 26, 2014 | Garden
    Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
    Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
    http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
    LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
    Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    I don't know how to restring the weed eater
    LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
    Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    The string on my grasshog xp gh1000 4, feeds out within 5 mins. What am I doing wrong when I add new string?
    Hello, W/D here.
    Read all the way through this, with the spool in your hand, before you re-wind the spools. It will make much more sense!
    Pull the spool off of the trimmer.
    Look on the bottom of the spool. The decimal numbers next to the notches on the edge is your line size (e g. .080). If there are 4 notches, there will be different decimal numbers, indicating that your trimmer can take different line sizes.
    Also on the bottom will be arrows, indicating the direction that you will need to wind the line.
    Looking at the spool, you'll notice that it is actually 2 spools, and the divider between them has a slot in it. (This will be important in a minute). The section of the spool closest to the bump head is the outer spool, and the spool closest to the machine, with the flat side, is the inner spool.
    Insert the proper sized line into the hole in the inner spool core about 1/8", and wind in the direction indicated by the arrows, until the line is just about even with the divider between the two spools, then place the line in the notch that is 180 degrees (on the other side of the spool) from the slot in the divider. When the line is in the notch securely, leave about a 6" tail beyond that, and snip the line.
    Wind the outer spool in the same manner, but this time, the line will go into the slot in the divider, then into the notch, and also get a 6" tail.
    Feed the tails into the grommets in the trimmer head, square them up, notches to grommets, and snap the spool in.
    Push the spool in like you were bumping it to the ground (this frees up the advance for the spool).
    Grab the two tails, and give a tug. The line will pull out of the notches and advance about 1".
    It's a good idea to clean out the hole where tha spool fits onto the trimmer from time to time, and also to put some graphite dust in the hole every 8-10 times you re-wind the spools, just to keep the mechanism working freely.
    Best regards, --W/D--
    Feb 09, 2011 | Black & Decker Garden
    Having trouble replacing trimmer line
    Hello. I just answered a similar question not twenty minutes ago. Hope this helps.
    Please read all the way through this before beginning to actually rewind the spools.
    1. Pull the spool off of the head. Clear the dust and debris out.
    2. Note that it is actually two spools that are separated by a disc, and that the disc has a slot in it. The outer spool is the spool closest to the bump head, and the inner spool is the one that fits closest to the machine and has notches in it. If you turn the spool so that the inner spool base is up, you will see that there are decimal numbers next to the notches. The decimal numbers are your line size(s). I say sizes here as some machines will accept more than one line size. You will also notice arrows on the inner spool base, telling you which direction to wind the line on to the spool(s).
    3. Wind the inner spool first: Put the end of the line into the hole that is in the core of the inner spool. insert ~1/8". Wind in the direction of the arrows until you get roughly even with the divider between the inner and outer spools. You want to end up with your line 180 degrees from the slot in the divider, and snap the line into the notch that is in the inner spool base. You want about 6" of line beyond the notch. Cut the line, leaving a 6" tail.
    4. Wind the outer spool: Wind the outer spool like you did the inner spool, filling the spool as before, and ending at the slot in the divider. Feed the line through the slot and snap it into the notch. Cut a 6" tail as before.
    5. Reinsert the spool: Get the spool close to the machine. Insert the tails into the grommets in the head, and snap the head into place.
    6. Preparing the line for use: Push the spool in as if you were bumping it against the ground to advance the line. Grab the tails and pull. This will release the line from the notches, and should release about 1" of line in doing so.
    You should be good to go.
    Every so often, it's a good idea to put some graphite dust into the spool just before putting the spool back onto the machine. This helps when you are advancing the line. I do this every 8 to 10 times I rewind the spools.
    If this fails to correct your problem with the spool, it would be best to purchase a replacement spool.
    Jan 31, 2011 | Tanaka 22" Double Sided 24cc Hedge Trimmer
    Hi I use all the nylon on the spool when cutting edges with in a 5 meter length ( 3 spools to do 15m approximately) Grass length 30 to 50mm
    Hello. W/D here.
    It sounds like the line is wound on the spools backwards, or the spool itself may be damaged. Here's what to do to fix it if it is improperly wound:
    Jan 31, 2011 | Garden
    I need directions to replace string on black and decker cordless 18v grasshog
    Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
    Otherwise,
    1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
    2. remove spool.
    3. place end of string in small hole in center ring of spool.
    4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
    5. snap string into notch on spool and cut string leaving 6" exposed.
    6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
    7. go cut grass.
    Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
    Ryobi 725R weedeater
    First unscrew the bump line leter outer. Then remove the yellow line holder, you will see 2 line grooves for each of 2 lines you will wind into the spool. You will see an inlet area at each of the 2 line holders, you will take about 8-10 feet of line and thread the line into the the groove inlet it will poke out the top of the spool. You will see 2 small holes on the top of the spool, feed just the tip of the line into the hole and pull the line tight on the groove side. Do this on both grooves on the spool, once the line is secure, fish each line into the holes on the spool head and secure with the bump spool leter outer. After spool is secure take the entire spool and wind back into the spool head. you will see the line wind into the spool. make sure you wind the right direction. Once you have seen how this is done, look at the bottom of your assembled spool and you will see 2 arrows. If you have no line in the spool, line up the arrows and take 8-10 feet of line and feed as you did when you have the spool removed. The line should feed through the spool and the line will stick up from the bottom, turn the line and feed just the tip of the line into the retainer hole and pull tight from the spool let-out, once secure wind line back into the spool. Once you have done this once its very easy to do over and over!!!
    Jul 21, 2008 | Electrical Supplies
    Garden Logo
    71 people viewed this question
    Top whipper snipper Garden Experts
    John Mayer
    John Mayer
    Level 1 Expert
    richie46
    ray gallant
    Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
