Why doesn't the display change when I press the dimmer button
Display stays dim. Won't brighten
  • 151 Answers
Either the screen is dimming with age or the default brightness was changed to dim as well.
Posted on May 10, 2014
  • 1,511 Answers
Dimmer may have been damaged from a power surge or excessive electrical power source. Could be expensive to repair, and be prepared if you need to have it serviced.
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
My hp elitebook 6930p display is very dim i tried the fn thing it didnt work how can i brighten the display
I had a similar problem--I had to disable the ambient light sensor to fix the problem: fn-f11. Now it's as bright as I need it to be.
Nov 02, 2010 | HP EliteBook 6930p Notebook PC
Overhead display too dim to use - can it be brightened?
I think it should brighten to the max with your dash light dimmer....You could put brighter bulbs in it.Hope this helps.
Aug 13, 2010 | 1993 Jeep Grand Cherokee
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
Dim radio/cd player display
The Bulbs have blown you can get special bulbs from the renault dealer have to pull off to of dash to fit
Dec 04, 2009 | Aiwa CDC-MP32 CD Player
When I turn on the headlamps the dash lights go out. Guages all work, radio display disappears also. fuse is good and tried changing headlight switch
Get a test light,and ground the clip,put the tip of the test light on the dash light fuse.Turn the knob to dim,and brighten the dash lights,see if the test light reacts with the dimmer switch.If it does not,then there is a wire jumped to by pass the dash lights somewhere.If the test light dims,and brightens,then there is a wire of going to the dash,or bad connection where the harness clips into the dash.
Oct 28, 2009 | 1989 Ford F 150
Display on Denon AVR-2307 won't work
It may seem obvious, but have you checked the display dimmer settings? Under the front cover is a button marked dimmer. Pressing it cycles through progressive display dimness settings until it goes off. One more press goes back to full brightness.
Dec 30, 2008 | Denon AVR-2807 Receiver
I accidentally dimmed my display screen, how do I fix it?
Hold the 2nd function button down while pressing the up arrow to darken the screen, alternatively hold the down button to brighten.
Nov 11, 2008 | Texas Instruments TI-84 Plus Calculator
26 people viewed this question
 Grubhead
Grubhead
