Question about Alert Wireless Alarm Alert System Motion Detector Driveway
How does the 93068 alert system work ?
I only have the base part that chimes the alert.what does the system consist of what else do i need ?
  • 1,511 Answers
Got to 10X . Com. a web site for these devices and you will se a number of additional units compatable with the base system.
Posted on May 10, 2014
2 Suggested Answers
cph770
  • 116 Answers
SOURCE: Was wondering if there is a way to mute the chime on Bunker Hill Driveway Alert System
No, you can't turn off the sound, but you can make it higher and lower, using the switch on the left side of the Receiver
Product Manual
Posted on Oct 04, 2012
My aftermarket radio is not working in my 2005 Chevy equinox. Do anyone know why? It's a new radio and all of the wires are connected properly. The chimes stopped working as well. Fuse are new as well
The chimes work through the factory radio , come out driver door speaker . There is a interface module you need to hook up on GM vehicles so aftermarket radios will work . With these newer vehicles your better off taking to someone or place that does this on a daily basis . Does it start an run ? If it does i'm surprised , factory radio is also hooked to the vehicle serial data network , class 2 . Suggest you google that .
Battery positive voltage is provided to the radio from the Radio (15A) fuse in the fuse block. The radio is grounded through a braided cable case ground. The radio is enabled/disabled by Class 2 messages from the body control module (BCM). The entertainment system on this vehicle is configured with a base and uplevel system. The base and uplevel systems contain a radio, antenna, speakers, and on some vehicles an audio amplifier.
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings. The BCM receives audible warning requests via the class 2 serial data line or the controller area network (CAN) data line. If the BCM receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Mar 15, 2017 | Cars & Trucks
My 2005 equinox has a NEW delco radio but the front speakers still dont work when you set the fader to the front
Do you still hear warning chimes ?
Do you have base or uplevel system ? Who put in the NEW delco radio ? I suggest you watch this video . GMC Acadia Diagnose Radio Volume Stuck On HIGH Part II A GM radio is the same for chevy , gmc , buick etc... an could need programming , just watch eric .He had radio fixed same problem .Some times you can't get away from going to the dealer.
Nov 11, 2016 | 2005 Chevrolet Equinox
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
May 13, 2016 | 2009 Chevrolet Cobalt
What causing my driveway alert system model 93068 to beep every 30 sec or so. I changed the batteries and that did not correct the problem.
Without a manufacturer I can't tell you for sure, however there are several things that can be causing this issue. The sensors used are either infrared or ultrasonic in nature and work by receiving a bounce back signal when something moves through the sensory field. I'd check to make sure you don't have any low lying branches waving in front of the sensor, gunk, mildew, or moisture build up (or ice/frost) on the lense or receiver, etc. If it's a wired system (for signal only) check for any intermittent breaks in the wire which could be causing a false signal, and if you're in an area with people using similar technology and this is a wireless system make sure there isn't any cross-signal interference causing the issue.
Jan 01, 2015 | Computers & Internet
Product Manual
Oct 04, 2012 | Alert Wireless Alarm Alert System Motion...
Does the bcm control the alarm in a 2006 monte Carlo? I can't seem to get the alarm to go off. I've also noticed that I have no chime and turn signal sounds. I just recently purchased this car and...
The no chime and turn signal has nothing to do with the alarm. You have a issue with power supply to turn flasher and door chime. The alarm consist of The door ajar switch,body control module,front door lock switch,power door lock switch. You need to check your fuse for turn signal and the door chime
Feb 22, 2012 | 2006 Chevrolet Monte Carlo
Carlon RC8800R how to set chime for westminster crime
The Carlon RC8800R door chime, quicks chiming usally within two days of mounting the base unit interior wall. If I take down and re-arrange the 4-D size batteries in sometimes starts chiming again. Is the base unit just a "lemon"?
Nov 29, 2011 | Carlon Wireless Doorbell system with...
Software errors
if ur looking for chime alert then at fuse panel is a round plastic chime that may be disconnected or needs replacement--if your looking for dash light then possible light is burnt or wiring problem under dash--
Apr 11, 2010 | 1999 Ford Crown Victoria
Have a series of 5 chimes 5 times believe its
The secondary air bag warning is an audible fault format that consists of five sets of five tone bursts, with each set of five tone bursts separated by a five second quiet period. One tone burst cycle will consist of one second ON and one second OFF. This series of five activations is repeated every 30 minutes.
This will tone if the air bag indicator is inoperative.
Suggest to have the dealer or someone with a scan tool that will communicate with the restraint system retrieve codes.
Mar 16, 2009 | 2002 Ford Escape
Alert Wireless Alarm Alert System Motion Detector Driveway Logo
347 people viewed this question
Top Alert Home Security Experts
Paul Bade
Charles Ma
Charles Ma
Five sok
Five sok
Level 1 Expert
Are you an Alert Home Security Expert? Answer questions, earn points and help others
