Philips BDP 3100 DVD Player
Philips bdp 3100 This DVD player does mot switch off either from remote or on/off button on unit. The tray also will not open. When entering the setup menu, the menu auto scrolls up/down without any prompting from the remote unit. The USB input works fine however and the unit plays from this. The unit did this with the previous firmware (1.54) and I had hoped the new firmware update would clear the problem (ver 1.701) but it has not made any difference. Regards,
SOURCE: CD Firmware update
I would strongly recomend that you put the unit under the rear tires of a large truck and back over it, that should take care of the problem.
Posted on Dec 04, 2007
diths_kri
  • 67 Answers
SOURCE: Firmware update for Samsung BDP-1400
 Samsung lists your version of the firmware as the EU version,
Posted on Jan 07, 2009
  • 98 Answers
SOURCE: Sony BDP-S300 won't play any Blu Ray discs
Sounds like a defective Drive
Posted on Feb 06, 2009
pabloloco
  • 2335 Answers
SOURCE: bdp s350 sony bluray player.
I would just like to add that I have a Sony BDP-S500 player and a Sony TV.
The Sony TV's remote was preprogrammed to control the Bluray player, which i discovered by accident, so I didn't have to mess with universal remote control codes or anything.
Hope that helps.
Posted on Oct 09, 2009
SOURCE: Trying to update firmware on
I had the same problem and immediately suspected that, as I had downloaded and expanded the .zip file on a Mac, I was suffering from the industry's usual bovine shortsightedness and that I needed to do it on a PC. I did and it worked. So I think the important part is to un-archive the .zip file on a PC, and find the file inside the resulting folder called
BDP12X_149.MVP
Make sure you have just that file on your USB stick, and no folders, and then the player should recognise it. You'll note that Pioneer's instructions don't mention this file name at all. Useless. Wish I'd bought another brand.
Posted on Dec 29, 2010
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
Unlock code for pioneer bdp140
Switch on the player & Remove any disc
Close the tray
Press Home Menu on the Pioneer Remote
Select Initial Settings
"Press the hack button on the remote" <-- The IR signal hack that's for normal DVD players with Philips pronto etc
Select Options using the Pioneer Remote
Select Load Default
Once defaults are loaded complete the Settings Wizard
Switch Player Off then On again
Press Home Menu on the Pioneer remote
Type 8520 on the Pioneer remote
Region setting should now be 0
Dec 19, 2011 | Pioneer BDP-120 Blu-Ray Player
Bdp-s300 non responsive after firmware update
Please follow the troubleshooting steps and check the operation.
  1. Power on the BDP-S300 Blu-ray Disc player.
  2. Immediately after "POWER ON" is displayed on the front panel display (within one second), press the "STOP" button on the player. The disc tray opens and the player turns off automatically.
    Note: Pressing the "STOP" button on the remote control does not work. It is necessary to press the "STOP" button on the BDP-S300 player.
  3. If the disc tray still does not open, repeat these steps but vary the timing of pressing the "STOP" button in step 2.
  • If the issue persists, please unplug the Blu-ray Player for more than 2 minutes and then reconnect it.
Please let me know if you require any clarifications. Thank you for understanding.
Feb 03, 2011 | Sony BDP-S300 Blu-Ray Disc Player
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
I want to make my sony bdp-s360 blue ray player region free. How to unlock?.....Help.
1.Make sure no Disc in tray
2.Press " HOME " on Remote
3.Press Number keys " 1389310 "
4.Power off then Back On
Now try a non-Region Disc
Aug 20, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Need code for Sony BDP-S350 for a Dish Network 622 remote
We would be happy to help you with that. Here is a list of codes that should address your DISH Network remote to your Sony Blu-ray player: 629, 671, 868, 617, 501, and 768.
Press and hold the DVD/VCR button located on the top of the remote until all the mode buttons at the top of the remote light up, then release. Use the number buttons to enter one of the codes for your Sony Blu-ray player, then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Phillip Chang
DISH Network Customer Service Representative
Aug 01, 2010 | Sony BDP-S350 Blu-Ray Player
Remote code for sony blueray model#bdp-s350
Hello All
Due to the Sony BDP-BluRay's needing a BLUE LIGHT SIGNAL to get past the Main Menu....There is no code or PUNCH THROUGH OPTION to read a INFRA-BLUE to an INFRARED signal from every other remote...Manopalized the market to Sony...No Play button will work after going to the maine menu of a BluRay DVD.
.....IF YOU CAN GET INTO SETUP ON THE PLAYER WITH ONLY A BDP-B101-105A REMOTE.....YOU CAN CHANGE THE REMOTE ACCEPTANCE.....WARNING MAKE SHIRE YOU CAN PULL UP A MENU and read about accepting other Remotes....
BEST TO BUY ONE FROM EBAY...25.00 to 35.00 OEM's are almost double......OK
Mar 03, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Pioneer BDP-f1FD Disc Tray Won't open
I fixed this on my unit from a tip on AVS Forum
Unit has "Power on" msg, follow these steps:
1) Hit power button for 5 -10 sec unitl unit shuts off
2) Press open / close button unit or remote first (do not hit power button first)
3) On the third try, the disc tray opened
I had James Bond Goldfinger in the player ( not sure if this had anything to do with it), I put another Blu Ray in and it loaded fine and is playing fine, hope this works for you
Dave
AVS link below
http://www.avsforum.com/avs-vb/showthread.php?t=1054927&page=413
Apr 20, 2009 | Pioneer BDP-51FD Blu-Ray Player
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
