Westinghouse TW-62401-U046A is not working. It
Westinghouse TW-62401-U046A is not working. It doesn't power on unless I unplug the ribbon cable for the right backlight. It looks like this is a common problem, but is there an easy fix besides installing a new main board?
  • 1,511 Answers
The ribbon cable may not be making a complete connection on all pins. Contact Westinghouse and ask for a replacement cable to a void the problem.
Posted on May 10, 2014
SOURCE: Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
Posted on Jun 18, 2008
VOTIT
  • 2071 Answers
SOURCE: Vizio VW42LFHDTV10A
I give you a site for do it your self repair..
http://www.lcd-television-repair.com/
Posted on Jul 07, 2008
  • 52 Answers
SOURCE: TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Posted on Aug 19, 2008
jhall1793
  • 60 Answers
SOURCE: "No Signal" for PS3 using HDMI cable
jareddirk30:
you didn't mention what software version your ps3 is. in this digital age it's important to keep software levels up to date, with some exceptions. i'm including the web address for sony so you can update the ps3, but i don't think it's the problem. once you're are on their site you click on the ps3 picture & that link will take you to the software update pg. there you can review previous software updates. i quickly reviewed 1 of those & didn't see anything that addresses your problem.
http://www.us.playstation.com/Support/SystemUpdates
have you verified that the HDMI inputs are are enabled correctly? thereare 4 inputs. refer to pgs 25 & 26 of the owner's manual.
I would put the heat on your LG retailer. clearly the new main board is suspect. you had the functions prior to the swap. the board is probably defective, but with a different problem than what you had previously. i visited LG's site. they currently have nothing in their knowledge base that mentions the your problem, nor is there a software update.
if you need additional help. write back. good luck.
peace-out
Posted on Feb 11, 2009
Fujitsu
  • 29 Answers
SOURCE: Vizio VX37L HDTV10A no picture
Hi.
You need change the Main board. You have a micropros. problem.
Posted on Aug 20, 2011
Bn44-00666a led voltages
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 12, 2016 | Samsung Televison & Video
My westinghouse 46" led tv will not turn on, tested the ac power supply and its good
The problem might be of its mother board itself. Contact any experienced service technician to make it confirm before change it. There are so many adjustments should be done after changing a new mother board. It is not a user reparable work.
Jan 16, 2013 | Westinghouse Televison & Video
LT1919WDB FLAKEY PICTURE
When the LCD Controller cable is diconnected from the LCD panel, the screen should be completely white due to the Liquid crystals do not have the bias voltage to block the backlight from coming through the front of the screen. Unless you have intermittent shorts circuits on the LCD controller board (part of the LCD panel) that load down the 5vdc (logic power supply). The capacitors on all the board look OK? See the pictures of bad caps in the monitors here and post back what you see on your boards so we can go further with troubleshooting.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 09, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
My hp dv9000 blue keys are on but moniter does not
First try a complete reboot, unplug the power and remove the battery for 30 seconds, then reboot.
if it still is dark the backlight may be out, try an external monitor to see if it works,connect the monitor and hold the FN key then press the switch to monitor button (F9 or F10, has a symbol on it) if the external monitor works you will need to replace the LCD screen or ballst (backlight power supply). voltage checks will tell you if the power supply is bad (do not attempt this unless you are comfortable taking it apart).
lastly sometimes the ribbon cable comes loose in the rear of the screen (inside) again will require disassembly to check and repair the cable.
If the external monitor does not work you may have a bad , video card, motherboard or memory.
Aug 03, 2009 | HP Computers & Internet
Help!!!
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Mar 18, 2008 | HP Photosmart D7160 InkJet Printer
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
