Question about Zebra 105SL Thermal Label Printer
How to check the MAC address of Zebra 105SL Printer
I would like to check the steps in obtaining the MAC address of
Zebra 105SL Printer
  • Anonymous Mar 13, 2014
    I can go into the program but it does not have IP address listed in the menu.
    I have 9 more printers that I changed the IP address in. The program menu in this printer will not give that item.
    Scholar:
  • 122 Answers
Go to the configuration on the printer. Scroll through until you reach the network settings. You can display or print the results, which will show the MAC address. Also, if you have a PC on the same network, and you know the IP of the printer, you can look at your ARP tables and find the MAC associated with the IP. ARP -a at the dos prompt
Posted on Jun 23, 2009
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
How do I changed the IP address on Zebra 105SL Thermal printer? I need the steps on how to do it.
To enter Setup Mode, press SETUP/EXIT.
Press (+) or (-) until you get to IP RESOLUTION and then press NEXT/SAVE
Press the (+) or (-) key to display Dynamic or Permanent.
Select Permanent to give set it up for Static.
Go back to the previous menu and go into IP ADDRESS.
Press the (-) key to move the next digital position.
Press the (+) key to increase the value of the digit.
**The IP will not take if it is set to Dynamic**
To leave Setup Mode, press SETUP/EXIT.
"SAVE CHANGES" will display.
Select PERMANENT by using the (+) and (-) keys and then hit NEXT/SAVE.
You should now have the IP you put in configured on the printer.
Mar 02, 2011 | Zebra 105SL Thermal Label Printer
Zebra 105SL is cutting off bottom line
check the length and the with from the driver, if is the correct with the current label. check the length and the with from the printer setings.
Nov 04, 2010 | Zebra 105SL Thermal Label Printer
How to install a zebra 105sl printer
Install? Well that could mean a lot of different things. Just plug it up and run the ribbon and labels through their correct paths. I don't know anything about your network. (If you even need to set it up that way.) You can just connect it to the back of your PC. Follow this link. This will tell you all about the specifications of the 105SL. Not really your connections though....... http://www.intermeccorp.com/pdf/105SLusersguide.pdf
Jul 09, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
Jul 06, 2010 | Zebra 105SL Thermal Label Printer
Need installation manual for rewinder on zebra 105sl
You can find the information about installation of rewinder in the printer manual. You can download that manual by clicking this link which I uploaded for you.
Hope this helps.
May 13, 2010 | Zebra 105SL Thermal Label Printer
Increase Speed on Zebra 105SL
In the driver there are settings for print speed, you will aslo need to access the menu on the printer and set the speed
Apr 27, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Nothing printing
have you install the correct drivers
Apr 24, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
5,411 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
