I have the right circuit breaker in the hvac tempstar unit i cant remember which wires to re connect 2 black and 2 red
  • 21 Answers
Connect to what the breaker or unit? If you switched the breaker and pulled 4 wires from a 2 pole breaker then logically the two blacks go together on line 1 and two reds go together on line 2. This is according to the color code.
Posted on May 10, 2014
How do I wire a Honeywell thermostat
Can I start by saying I am not in anyway saying to do this alone it is dangerous but if u must follow each step start by being safe shut off the breakers good luck here to help
Step 1
Turn the air conditioning and heating unit off by flipping the appropriate circuit breaker. Test the unit to make sure it's off by turning your existing thermostat to the "On" position and seeing if it turns on. Wiring a Honeywell thermostat when the circuit breaker is on could cause you to blow the transformer that powers the HVAC unit Step 2
Connect the red wires to the thermostat RH, thermostat RC or thermostat R terminal. The thermostat RC terminal has a jumper wire between thermostat RH and thermostat RC. The thermostat R terminal operates both the heating and cooling units, and contains an internal jumper wire. Basically, your red wire on a Honeywell thermostat is the hot wire that run. Step 3
Run the green wire to the thermostat G terminal. The green wire controls the relay that operates the blower, and it controls the fan. Step 4
Control your air conditioning when you connect the yellow wire. It connects to the thermostat Y terminal Step 5
Hook the white wire to the thermostat W terminal to control the heating unit
Nov 20, 2014 | Heating & Cooling
Tempstar hvac trying to change 60 amp circuit breaker on unit cant remember which red and black res go together
it shouldnt matter what orentation the wires are,each one is 110 volts from both feeds, together they make 220 volt.the differant colors are just for idenification of the cable at each end
May 10, 2014 | Heating & Cooling
I NEED TO KNOW IF IT MATTERS WHAT WIRES ARE CONNECTED TO A 40 30 AMP CUIRCUIT BREAKER
What kind of cuircuit breaker is it 40 or 30 amp breaker it makes a big diference for 30 amp breaker you need # 10 wire
for a 40 amp you need # 8 wire
hope this will help.
Karl
Dec 17, 2011 | Electrical Supplies
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
What is a wire lug in my AC unit?
A lug is defined as a screw terminal made to accept one or more wires. Lugs as such are found in Circuit Breaker boxes (and on the circuit breakers themselves) Electrical junction boxes, Contactor relays such as found in Central Air units, those all being fairly large. There are also small lugs as would be associated with small wires such as thermostat wiring. Terminal diagrams for user-made connections are always provided with the unit being connected be it thermostat or HVAC unit. The thermostat comes with written documentation including diagrams, HVAC units typically have a diagram glued to the inside of the access panel.
Electricity can be your friend but can also kill you. Disconnect the power before altering or making any connections. If you don't know what you are doing, don't become a statistic, get help.
Jul 12, 2009 | Heating & Cooling
I have a tempstar 2000 heat pump approx 5 years old. The condenser fan blades will not rotate/operate; however, I can hear the motor hummming. When the unit is off, I can rotate the fan freely. When the...
I think this is a double problem post,so I will answer the top first.
The fan capacitor may be bad or the motor it's self is seizing up and will need replaced.
Second portion of post:
  1. Brown and brown/white go to the new capacitor(If you didn't get a new one with the motor,You will need to)Should be 7.5 mfd
  2. Black To the contactor where the black was originally connected
  3. yellow to the contactor where the red was originally connected
May 06, 2009 | Heating & Cooling
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Trying to install a 30 amp breaker into a ge powermark gold 200
Hello, First, you need to determine if you are installing a 220 or 110 vac circuit breaker. The 220 is a "double pole" and will have (on the underside) 2 tabs for each 110 phase on your breaker box. It will also usually have a double switch tied together. A single or 110 breaker will just mount to one of the "hot bars" on the breaker box. Again, look at the underside of the breaker. Just remember you need 2 wires (usually a black and a red) for 220 and only one wire (usually black) for a 110 single. The neutral shouls tie to the neutral bar on the box (where all the white wires are connectoed to)
Of course, use extreme caution and insulating gloves when working on a circuit breaker.
Hope this helps and good luck with it. Gary
Mar 12, 2009 | Electrical Supplies
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
