Question about Honda Electrical Supplies
How do i change oil in a honda 9.0 g270 generator ?
2 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: water in oil
Natural gas and Propane engines do create moisture in the engine because these are cold gases. Therefore, when the engine is done running, the engine is hot and whatever gas is left will condensate and the moisture will drop to the bottom of the engine or oil pan. If this is using these gases then it is normal what you are seeing.
Posted on May 07, 2009
Honda generator wont start it was running fine.
If you filled the fuel tank with gasoline enhanced with ethanol the fuel may be bad and caused the carburetor to gum up. Also Honda engines have a low oil sensor and from your description of the oil, can cause problems with the sensor and the engine won't start. Try changing the oil first and then adding a small engine gasoline additive that helps with stale gasoline starting problems.
Sep 10, 2016 | Honda Electrical Supplies
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
My honda 2000 generator only runs for about 3 seconds then shuts off
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
Sep 03, 2014 | Honda EU2000IKN EU 2000 Watt Generator 50...
2008 Honda DN-01 how to check the oil
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $9 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
blinking oil light
How to change oil on Honda 4 stroke motorcycle
2009 Honda DN 01 NSA700A Motorcycle Factory Service Manual $9 cheap
http://www.partsfish.com/page/oem-parts-for-honda
Honda NSA700A DN 01 Owner Manual
Oct 10, 2013 | 2008 Honda DN-01
It starts with the switch fine but when i let go of the key it cuts off
Check for faulty low oil sending unit or oil level low or dirty oil (some generators have a fuel cut-out solenoid at the carb ). Key switch will override the low oil safety. Easy test, remove wire from oil sending unit. If unit runs, and oil has not been changed in a while, service engine and retest.
Sep 09, 2011 | Mi T M MiTM Generator 9hp Honda 5000 Watt...
Need service manual for a Honda ES4500 generator
Where do you change the oil on a Honda ES 4500 Generator?
Dec 26, 2009 | Honda Electrical Supplies
Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
May 28, 2009 | Electrical Supplies
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
DOES NOT CHARGE
If you still have it I have one I dropped. The body is still fine, and the batteries charge. A piece broke off inside the cutting blades. Let me know if I can help. Thank You, Jeff
Jan 15, 2009 | Norelco G270 Beard Trimmer
Electrical Supplies Logo
13 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
