Question about Samsung SCX Office Equipment & Supplies
What means "the current printer port is not supported for printer status"
3 Suggested Answers
SOURCE: keep getting error msg: printer status shows not
You have to be sure that you are connecting the printer in exact the same USB port. If you are connecting to a different port and not to the one from was disconnected, the Windows is installing another copy of your printer. Check this, I believe this is the solution to your problem.
Posted on Aug 24, 2009
pineworks
  • 4041 Answers
SOURCE: getting error message the current port is not
Hi there
Go to start and then go to your settings control panel and then click with your mouse on printer and open printer then click on the printer icon you using with left side mose to properties then you will see the tab says port just try a dierent port till you get it right
All the best Pineworks
Posted on Mar 17, 2010
CHECKING THE INK LEVEL
to check the toner level just press the button and wait the second light(orange) to turn On and then release the button. The printer will print two pages one with configuration and one with the supply status of the toner cartridge
Dec 26, 2015 | HP LaserJet 1300 Printer
Tip
Samsung SCX-4500W restore wireless printing on cryptic error
For those having trouble wirelessly printing to their Samsung SCX-4500W printer from a Windows computer, I have this "easy" 13-step process that usually fixes my most common printing problem:
The symptom:
You haven't used your printer in a couple of days and have just hit the print button in an application you wish to print a document from. Instead of your printed document gracefully emerging from your printer, a Samsung status window appears on your computer above the task tray, cryptically announcing "The current printer port is not supported for the current printer status". You scratch your head in complete confusion.
The solution:
  1. Go into the room where your printer is. Observe that it has dropped its wifi connection and not reconnected automatically - the blue light indicating wifi is no longer illuminated.
  2. Turn off the printer, wait a few seconds, and turn it back on.
  3. Rebooting always causes a blank page to be ejected - how annoying! Open up the tray and reinsert the blank sheet.
  4. Wait for the blue wifi light to come on.
  5. Return to your computer and open the printer job queue window. Locate your document in this window with "Error" status next to it: right-click on it and select restart so its status changes to "Printing".
  6. After a while, notice the status has changed to "Error - Printing" or "Error - Sent to printer". Since restarting the job was not successful, right-click and select cancel. Press the OK button in the confirmation dialog. You may have to do this a second time before the job clears.
  7. Return to the application you printed from and re-print the document.
  8. Double-click on the blue Samsung "S" icon in the task tray. A window titled Samsung SX-4500W Series will appear in the lower right. Observe the status first says "Please wait..." then show the same cryptic message "The current printer port is not supported for the printer status". Grrrr.
  9. Check if your computer really can access the printer by opening web browser and typing its ip address. For me, it is 192.168.1.70. Alternatively, click the "Printer Setting" button in the window of step 8. Observe that the printer reports it is alive and ready for action. This is good.
  10. Check if any other Samsung software is able to use the printer: Open SmarThru 4 software, select "Scan To", "Folder", then hit "Scan" button. Observe that scanning from the printer works absolutely fine. Close SmarThru. So the problem is just the crappy printer driver.
  11. Close any Samsung windows you have open. Navigate the start menu to Samsung SCX-4500W Series->Maintenance. The installer will run in maintenance mode and find your printer on the network (and show its ip address), as well as an option to use it on "Local Port". Select the printer on network and click Next. Select "Samsung SCX-4500W Series printer driver" to repair and hit Next. The driver will re-install. Click Finish when done.
  12. Return to your application you wish to print from and activate the printing of the document again.
  13. The Samsung status window will once again appear in the lower right proclaiming "The current printer port is not supported for the printer status". Ignore this stupid message and close the window. Go to the room with your printer and with any luck, you will find your printed document waiting for you!
Once you are well practiced at this, and can fully appreciate how useless Samsung's software developers are, you can just do steps 1,2,3,4, 5, 6,11,12, and 13.
on Mar 09, 2011 | Samsung SCX-4500W WiFi Multifunctional +...
I want to update my bios
Oh?
Kvpsy,
The information tells me;
1) Operating System: Windows XP Pro with Service Pack 3 (SP/3)
2) Processor: (CPU) Intel Pentium 4, 3.06GHz,
(Or also stated as 3.066MegaHertz) {3.066MHz}
Uses an LGA775 processor socket.
Front Side Bus = 133MHz.
(Intel processors are 'Quad Pumped'. 133MHz is the Internal Clock. 533MHz is the External Clock.
4 x 133 = 532. Number is rounded up to 533)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
Scroll down.
Prescott Core, 90nm architecture.
Pentium 4 HT model 524.
sSpec number on top of the Processor, (Heatsink removed), is either
SL8ZZ, or SL9CA
3) Motherboard manufacturer name, and model number:
Intel D101GGC
Version AAD357
3) Motherboard chipset:
ATI Radeon Xpress RC410 = Northbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
IXP450/SB450 = Southbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Southbridges_2
4) GPU: (Graphics Processing Unit, or slang = graphics chipset)
Built into the motherboard chipset; ATI Radeon 200 series with 256MB's of graphics ram memory.
(? Really? I would think more like 64MB for Integrated Graphics.
Are you running a graphics card, in the PCI-Express slot on the motherboard? Got one in one of the PCI slots?)
5) Ram Memory:
2 Ram memory slots
DDR Sdram at 400MegaHertz. Also known as PC3200.
Maximum TOTAL amount is 2048MB. (2GB)
Amount of ram memory that installed now, 1024MegaByte. (Or also stated as 1GigaByte)
960MB is what shows.
(64MB's of ram memory is being borrowed)
32MB DRAM modules. Memory module/s ('Stick') use 5 Volts (DC)
60nanosecond to 70ns, Cas Latency of 3. (CL3)
6) Harddrive:
IDE
Western Digital WD1600AABS
150GB
7) Optical Drive:
IDE (EIDE really)
Manufacturer = LG Electronics
Model number = GH22NP21
DVD burner drive
8) C-Media CMI8738 audio (Sound) chipset
9) RTL 8139 Ethernet chipset
10) Basic Input/Output System (BIOS) manufacturer = Phoenix/Award.
Version = 6.00PG
Release date = 04/20/2006
BIOS String ID = GC11010N.86A.0311.2006.0420.1525
NOW, the message you received is -
SUGGESTION: Are you looking for a BIOS upgrade?
System BIOS is more than 2 years old. (WELL NO KIDDING!!)
Video BIOS is more than 2 years old. (Yeah? AND?)
A) AS SOON as you purchase a motherboard, the BIOS program is ALREADY out of date.
BIOS upgrades are made about 2 weeks, after the motherboard hits the market.
TWO WEEKS!!
What does this mean?
It means LEAVE IT ALONE.
If everything is working OK, DO NOT perform a BIOS upgrade.
Why?
Because for;
1) IF, the power goes out to your house/business, when you are downloading, the BIOS upgrade WILL NOT be completed.
What does that mean?
Take the motherboard out of your computer, and use it for a Frisbee.
2) IF, the BIOS upgrade is too new, and/or NOT compatible, AND if you do not save the old BIOS version, take the motherboard out of your computer, and use it for a Frisbee.
IS there a cure for ruining the BIOS program in your BIOS chipset, on your motherboard, and downloading, and installing the original one?
SURE!
Take it to a PRO, who will download the ORIGINAL BIOS, to a Floppy Disk, (Or disks), using an internal Floppy Disk drive, connected with a floppy disk ribbon cable, to your floppy drive connection on your motherboard, and put it on your motherboard.
MAYBE.
(Not shouting. Illustrating a point)
OR, if the BIOS chipset is removable, (It is soldered on the motherboard), perhaps another BIOS chipset is available, for a PRO to solder the good one back on the motherboard.
You HAVE been advised.
BIOS upgrade download page,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021749.htm
Motherboard Manual,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Regards,
joecoolvette
Jun 16, 2012 | Intel Computers & Internet
CLP-325 "The current printer port is not supported for the printer status"
Dear
Try to replace the usb cable. Also from pc program do the maintenance program run.
If still problem found check the printer with other pc or the pc usb port for other device if it works then replace the main PBA of the printer.
Thanks.
Apr 28, 2012 | Samsung CLP325 Laser Printer
I have ncomputing L300 thin client with usb port. I attached Cannon Laserjet LBP2900 to thin client usb. also installed drivers on host. printer is detected & shows printer ready. but when i give...
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Apr 21, 2011 | NComputing L230 Network Terminal
It suddenly went offline after printing a document. When I turn it off & on again, it manages to print the current job but then goes offline.
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Jun 22, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Getting error message the current port is not supported for the printer status
Hi there
Mar 17, 2010 | Nikon COOLPRINT Thermal Printer
HI CAN SOMONE HELP ME WITH MY PRINTER ITS A EPSON STYLUS DX5050,WHEN I CLICK ON PRINT NOTHING HAPPENS, A WINDOW OPENS ON PC SCREEN & IT SAY STATUS PAUSED. HELP THANKS KEV
STATUS PAUSED means your printer Epson is not connected. Check the port USB at the back of the PC yet connect it properly.
At the Printer Panel see if the printer is ready or not. Usually this problem occur when the port setting of the printer defaulted at LPT1.
Nov 13, 2009 | Computers & Internet
Keep getting error msg: printer status shows not attached to local port. how to recover shows non-LPT/USB port connections are not supported by this status monitor. printer worked a few days and now...
Jul 08, 2009 | Konica Minolta PagePro 1350W Laser Printer
I can not get two print servers to work on my network
I would suggest that you set a higher Ip address then 9-10 as it is possible that your router/switch is possibly using one of these for DHCP, I have one of these myself, I had to put mine a little uprange to prevent my router / switch from interfering with it.
Jul 26, 2007 | D-Link DP 301U (DP-301U) Print Server
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
