Question about Pioneer Audio Players & Recorders
Philips bdp 3100
This DVD player does mot switch off either from remote or on/off button on unit. The tray also will not open. When entering the setup menu, the menu auto scrolls up/down without any prompting from the remote unit. The USB input works fine however and the unit plays from this. The unit did this with the previous firmware (1.54) and I had hoped the new firmware update would clear the problem (ver 1.701) but it has not made any difference. Regards,
SOURCE: CD Firmware update
I would strongly recomend that you put the unit under the rear tires of a large truck and back over it, that should take care of the problem.
Posted on Dec 04, 2007
suffolkpo
  • 6 Answers
SOURCE: Denon AVR 1803
Hello, I think that you've got a problem in the relay circutry or a logic problem. tell ya what I ve got the service manual and schematic for the reciever. the engineers at denon where ahead of there time when this company started. they designed the equipment around what they wanted the specs to be for signal to noise and discrete audio channels. each of the sound channels from the component and composite inputs is given its own bus and amplifier channels. these paths are also common to the reciever/tuner outputs. one question though you mentioned that the composite/component video paths are not switching from the input to the output youve designated, and that the monitor checks good. do you have another video source,either digital or analog that you can input throgh another channel to see if it is infact a switching problem. try that and let me know. I can give you help with the switching circutry form the schematic if need be. believe me I know It took me about a week to track down the service schematic for this unit. Denon doesn't like giving out info unless you are an authorized repair center.
Posted on Jan 03, 2008
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
SOURCE: Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Posted on Jul 15, 2008
SOURCE: DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Posted on Sep 08, 2008
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Need to unlock tf-dvd7008
Step 1- open the DVD tray
Step 2- Press the "MENU" button on the remote control
Step 3- Press" 8888"
Step 4- Press the " DISPLAY" button
Step 5- Select your region. I would suggest enter " 0", this will make it a all region player.
Step 6- Press the " SETUP button to exit.
Mar 31, 2009 | Coby TF-DVD7006
Locked dvd tray.
Press Setup then the numbers 2 0 0 5 then setup and it should unlock
or
Display 2 0 0 5 Display
Dec 22, 2008 | Toshiba SD-K760 DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Dvd8723uk curtis dvd player wrong region
region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Sep 09, 2008 | Digix HT1056A DVD
Fix for DVD Player
Try making DVD player multiregion
Or
Or
2) Open the tray
Aug 31, 2008 | Digix HT1056A DVD
Curtis region error
This region code solution as per
Or
Or
2) Open the tray
Aug 17, 2008 | Digix HT1056A DVD
DVD8723UK
this region code solution as per
Or
Or
2) Open the tray
Jul 11, 2008 | Digix HT1056A DVD
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Apr 19, 2008 | Philips DVP5140 DVD Player
98 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
