Question about Husqvarna Zero Turn Mower Z5426
Husqvarna with Kohler twin has crankcase FULL of gasoline. WHY?
    Scholar:
    New Friend:
  • 61 Answers
It's highly possible that it's either in the carburetor (something holding the float down allowing fuel to fill the carburetor and over flow draining into the cylinders, possible porous float or debris between needle and seat.) Or it could be drawing or sucking it in through the fuel pump vacuum line between the engine and fuel pump. I would be looking into these two areas.
Posted on May 17, 2014
  • Husqvarna Master
  • 2,478 Answers
If you have one, fuel solenoid bad or etc. Carb float needs adjusted or hole in it. I installed a fuel shut-off valve, to stop things like this.
Posted on May 10, 2014
2 Suggested Answers
  • 15261 Answers
SOURCE: gas in the crankcase
need to do compression test to test piston rings and check carb float possible sticking allowing fuel to keep flowing
Posted on Apr 08, 2010
Have a Cub Cadet Lt 1050 when you start it, continues to turn over and not start.
Check your oil. Most cub cadets use a kohler engine which will allow gasoline to drain into the crankcase and fill it with gas. The fuel must be shut off on kohlers which can cause unwanted flooding due to a stuck float. You may be surprised when you open the oil check and find gasoline coming out. If not, lightly sand the magneto and the flywheel to make sure you have a spark. If you do have a spark, it is most likely a gasoline issue caused by the flow being stuck in the bowl of the carburetor, causing a Kohler not to start
Sep 02, 2016 | Cub Cadet Garden
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
now the kohler v-twin does have a bit of a problem with camshafts in this size range , your gonna need to remove valve cover on head side that you suspect is bad , verify that valves move in order (one at a time) as you turn over by hand with spark plugs removed (both sides)
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Gas in the crankcase is caused by what?
the carb is the culprit. either a stuck float or needle valve and carb are full of gunk preventing it from getting a good vacuum. you will need to remove carb, and flush it out to clean it. may god bless!!
Aug 16, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Need torque specs for oil pan
here is website for kohler
http://www.kohlerplus.com/main_frame.asp
select command pro twin
then select tp2428c service manual
it has all the details you need
cheers hope it helps
paul
Aug 05, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Apr 08, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Zero Turn Mower Z5426 Logo
85 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
