Question about LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator
LG refrigerator is not making ice does it have a reset button?
4 Suggested Answers
SOURCE: refrigerator stopped making ice
Did you get an error message? We have turned our ice maker off, left it off for about a week, then turned it back on. Some part inside freezes and, so far, this method has worked.
Posted on Sep 03, 2009
ZJLimited
  • 17970 Answers
SOURCE: My LG refrigerator is not
There are a few reasons why your water may not be working. The first is that the fresh food side of your fridge is too cold and it has frozen. You can check that by removing the crisper drawer and checking the reservoir behind it. You can thaw the water with a hair dryer on low setting.
The next possibility is that it is your filter. If you have not replaced it in the last year, now would be a good time to consider doing so.
The last and most probable is that the water valve on the back of your fridge has failed, and not letting the water in for the ice maker and water dispenser.
This can be replaced by unplugging the fridge and removing the rear cover. You will see the valve where the water line is connected. There are several variations of this valve and you can click the link below to match up what you have.
Once you have matched the valve up, you can replace the cover and plug the fridge in. One of the biggest reasons that I use the site below is that they have excellent service after the sale including support for installing your part; according woth the right model, CHECK REPLACEMENT HERE.
Keep us updated.
Posted on Apr 18, 2011
richroth
  • 9472 Answers
SOURCE: where is the reset button on a french door lg refrigerator
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigeratoricon1.png will enter Test Mode 1. Test Mode 1 allows diagnostic operation of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heatericon1.png off.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 2 and hold for 3 seconds. The refrigerator will enter Test Mode 3. Test Mode 3 allows diagnostic operation of the compressor and freezer fan off, stepping damper close and defrosting heater on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and hold for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
Unplug the refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
There is no reset button.
Posted on Nov 01, 2012
Ice maker stopped working in lg refrigerator lfx25976st/00
I just slide the ice tray to the left and down till it unhooks from the right hand side. Then unhook the wires from under the tray. To replace just repeat in reverse order. I have to take our ice tray out ever so often to clean it since we have well water.
There is a little square button up under the left hand side in the back. If you press that with a screwdriver or butter knife it will reset the ice tray and it return it to fill with water.
Sep 03, 2012 | LG Refrigerators
LG refrig with freezer on bottom, french doors Model #LFC237605SW lights went out - is there a reset button?
There is no reset button. Make sure the light bulb has not burned out. It's possible that ice has frozen the light switch. Use a hair dryer to the ice switch to see if it will melt the ice and release the switch. Good luck
Jun 19, 2011 | LG Refrigerators
The ice maker has quit. Water is working. Is there a reset button.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
5
Dec 15, 2009 | LG LFX25971ST Bottom Freezer French Door...
My LG LSC27926ST will only make crushed ice, no whole ice cubes.
I've got the same problem - It looks like the auger which crushes the ice cubes is forced on regardless of which ice button you press. My best guess is some sort of software problem is causing it, but I can't find how to reset it
Nov 24, 2009 | LG LSC26905TT Side by Side Refrigerator
Power went out, now can't get the icemaker to restart
in the front panel its a reset button, Push the ice/water button and push the release button it should reset and start working again
hope it helps
Sep 29, 2009 | LG LFX25960ST Stainless Steel French Door...
LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Jun 28, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
Icemaker not making ice - feeler arm in up position
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Jun 18, 2008 | LG LFX25960ST Stainless Steel French Door...
ALl of the buttons on the outside are jammed...
press and hold both the water and ice button together to reset
Nov 06, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
37 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
