Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
Where could I get a charger for scoorer turbo 280wf
    Master:
  • 427 Answers
There should be a manufacturers sticker on the scooter somewhere(probably around the battery, under the seat, or around the steering neck) which will have a contact number for who ever made it. Call them and they will tell you who distributors are and who carries the the charger.
Posted on May 10, 2014
Nissan elgrand e50
fit a turbo charger to it . Need a turbo charger --a manifold for the turbo charger and an up graded chip in the CPU to get it all running properly and a lot of dollars
Jan 07, 2014 | Cars & Trucks
Elantra 2004(Diesel, done 136,000km) Leak in Turbo Charger
A turbocharger can leak. Some of the gaskets might be shot and need to be replaced or a hose might need to be replaced. If the turbocharger itself is leaking and not a gasket then the turbo housing is probably cracked. If you get the turbocharger replaced it should last a good 20 years or so. The only thing that usually wears out on turbochargers are gaskets and thrust bearings.
Mar 24, 2012 | 2004 Hyundai Elantra
My 04 VW Jetta blew thick white smoke from tailpipe after freeway drive. No indicator lights came on, all oil leaked out (after smoke started)... is this engine or could it be just the turbos? Right...
A new turbo charger is about $340, but you can buy the bearings and seals and rebuilt if yourself for about $100
http://turbosandparts.com/
It is not hard, and it does not take long to do.
I normally do not bother with synthetic, but with a turbo charger, it might be worth it. What really seems to ruin turbo chargers the most is not letting them cool off before parking.
Once you turn off the engine, there is no longer any cooling, so the build up heat will burn up the oil and seals.
Run the engine for at least 5 minutes below turbo levels, before shutting down the engine.
Sep 06, 2010 | 2004 Volkswagen Jetta
Whats the make-up of the r?otating assembly
It all depends on how much pressure you intend to run the turbo or supercharger at. If you won't exceed around 12 psi, you can keep the engine stock without damaging or shortening the engine life too much. If you wanna go bigger than that, you might need to upgrade the pistons and crank. And as for compression, either a charger or turbo will do the same thing as far as the compression is concerned, so if compression is too high for a turbo, it's too high for a charger also. And I'd start checking more for upgrading the fuel system than the engine assembly parts, cause you will need more fuel in the engine to compensate for more air coming in due to turbo or charger way before you need to strengthen the engine for the extra power.
Jul 08, 2009 | 1999 Ford Mustang Cobra
My turbo charger: VW Touareg 2.5 R5 TDi to buy
you can buy a rebuilt kit from the manufacture who supplies vw with the turbos.
Jun 12, 2009 | 2005 Volkswagen Touareg
Replacement turbo chargers
My best advice to you would be to check www.passatworld.com Look into the forums and use the search function. There is an unbelievable amount of information with just a little bit of searching. And there may be some turbos for sale on there as well. If you can't find anything in your price range, check out a chip... slightly cheaper and just as much power gain as you would from a larger turbo. You will have to chip it if you drop in a larger turbo anyhow. Hope this helps!
Apr 28, 2009 | 2003 Volkswagen Passat
Tdi Turbo Charger
Most likely yes, but you may want to investigate whether a second-hand turbo is a better option price-wise. I don't know what the TDI turbos sell for, but on the gas engines, the stock K03 turbos only go for a couple hundred dollars (or less) used, with no endplay. It may be less hassle to just source a replacement in order to get your car back on the road. You could then have your turbo rebuilt at your leisure and keep it as a spare.
Aug 02, 2008 | 2002 Audi A4
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
65 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
