Question about Sanyo PLC XP46 Multimedia Projector
After lamp replacing on Sanyo PLC-XP46 the projector starts up and immediately & suddenly shuts down.
The projector was working perfectly before replacing the lamp. When I reinstalled the old lamp it worked without any problem.
  • 3 more comments
  • Ayman Nofal
    Ayman Nofal May 12, 2014
    I bought another new lamp and and installed in the projector and turned it on but the same problem appeared again.
  • Ayman Nofal
    I thought the problem in the lamps, So I tested the two lamps by using a lamp tester but both lamps light on, so the lamps are working and no problem on them. there is aproblem in the projector itself. so anyone have any suggestion?
  • Ayman Nofal
    Also I cleaned the projector, filter and fans. but Where I can find the iris door. Can you show me a diagram of the unit? Thanks
  • paul reynolds
    paul reynolds May 12, 2014
    the iris door should have a plastic key, when inserted correctly the projector will start if it has snapped off then the projector will not run and will turn off.
  • Ayman Nofal
    Ayman Nofal May 13, 2014
    Where I can find the iris door? Can you help me please. Thanks
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: After lamp replacing on Sanyo PLC-XP46 the
Check the iris door, it opens and closes freely. If dust has clogged it up, it will not stay on. Also check the air filter and the fan, if they are dirty, it will shut down as well. If your manual does not show any diagrams of the unit, post a comment and I will look it up. Hope this helps.
Posted on Jan 11, 2011
Hello.... Sanyo PLC-SU20N projector....shuts down within 3 seconds of turning on.
If the lamp doesn't strik, it will.
Check the ballast unit and lamp age.
Mar 19, 2011 | Sanyo PLC SU20N Multimedia Projector
I have a Sanyo PLC XU45 projector which recently gegan to shut down after about 10 secs after switch on countdown (30s). All Fans working OK. I've cleaned the filter (which was clogged). Funny thing, when...
How many hrs are on it? I suspect the lamp is going out of it... Buy another lamp and go from there. This way even if it isn't the lamp you will have one in stock. But if it is, you have just fixed your porjector.... Good luck..HDTV GURU JAY
Mar 18, 2011 | Sanyo PLC-XU45 LCD Projector
After lamp replacing on Sanyo PLC-XP46 the projector starts up and immediately shuts down. Lamp counter was reset.
Jan 11, 2011 | Sanyo PLC XP46 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Aug 04, 2008 | Office Equipment & Supplies
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo PLC-XT16
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
Apr 15, 2008 | Sanyo PLC-XT16 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Open Questions:
Sanyo PLC XP46 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
