Question about Sewing Machines
Pfaff 1647 blocked
The machine is blocked, it lights up but won't move , won't work...
    Sergeant:
  • Sewing Machines Expert
  • 381 Answers
Take it to a repair shop and have it repaired.
Posted on Jun 16, 2014
2 Suggested Answers
  • 1564 Answers
SOURCE: My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Posted on Nov 30, 2012
When I turn on my pfaff only the green lights and light bulb come on. Display area does not and the foot petal does not work. Witch board do I need and where to get one? Thanks
PFAFF Mail-A-Repair Garry's Machine - YouTube
? 10:15
www.youtube.com/watch?v=x1CmpFRr8OU
Apr 20, 2010 - Uploaded by kennsplace Ive been working on sewing machines for the last 18 years. ... a used pfaff 2022, and it works great, except that reverse does not work. When I ...
Sep 19, 2015 | PfaFF Sewing Machines
Nov 28, 2012 | Sewing Machines
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Jun 03, 2012 | PfaFF Sewing Machines
I've just bought a Pfaff 1471 and it has "locked-up"... the needle won't go up and down and the hand-wheel won't move. Help please! :)
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
May 10, 2011 | PfaFF Sewing Machines
My machine jammed up with some thread under the fabric but nothing by the bobbin. but the needle won't move it just hums when I try try to sew.
If you can't turn the handwheel, then there is thread jamed up in the hook. You can try to rock the handwheel back and forth to try to get the thread out. If you do get it free, try to sew with it. If it won't sew properly you might have a damaged position finger or it's out of time. You'll need to take it to a PFAFF dealer.
Apr 22, 2011 | PfaFF Creative 7570
Where are the oil holes in a pfaff 1222e sewing machine
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Jan 26, 2011 | PfaFF Sewing Machines
The foot control for our 1214 pfaff sewing machine burne out (quit working) we took the machine to a repair shop and they replaced the foot control with a "Supreme" electronic foot control. The machine has...
if the first guy did not replace it with a pfaff foot it will not work right the pfaff machines will work backwards of normal power feet and they have to be replaced with pfaff feet
Aug 03, 2009 | Sewing Machines
Pfaff 2058 Voltage switch
There is a small clear plastic piece blocking the switch that must be removed, then use a small flat screw driver to flip the switch, you can throw away the small piece, it is only needed for shipping.
good luck!
May 25, 2008 | PfaFF Tiptronic 2040
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Apr 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
