Question about Nikon D3100 Digital Camera
How can i turn on my Nikon D3100?
During a firmware update my nikon d3100 shutted down. since then it became inoperable. i also mention i don't have any problemes with it's battery. I can't figure out how to make it power on
Is the battery fully charged. What were you doing on it right before you shut it down. Also make sure your putting the battery i. The right way
Also you can\'t charge the battery by usb into a computer. You need to use the external wall charger.
Unfortunatly the d3100 does not contain am external reset button like the Nikon D3000 but this might help. Take out the sd card and battery and leave it out for a couple hours then, after a couple hours have past reinsert the Battery without the SD card. If it still doesn\'t work shine a flashlight into the battery holder to see if any of the metal connectors are bent.
The only logical explanation after that if it still doesn\'t work is that the battery died doesn\'t have to look damaged it can crap out anytime. I would try getting a new battery and putting it in. If you just got the camera you could tell the place you got it at and they should give you a new battery.
i hope I could help, your going to have to trial and error this one to see what gets it to work.
Posted on May 10, 2014
  • 406 Answers
SOURCE: Nikon D3100 - how to
For Quick Response Mode and other Release Modes, please see "image1":
For remote control shooting or Bulb mode, see "image2":
image 2
Posted on Nov 24, 2010
  • 2385 Answers
SOURCE: What settings would you use on the Nikon D3100
Hello
Here are some general guidelines for shooting fireworks:-
Get a good position! Try to determine approximately where the fireworks will be bursting. And get a spot with an unobstructed view of that area. You'll probably need to show up early to get a good spot. Figure out the wind direction and get upwind of the fireworks so that your shots aren't obscured by smoke blowing toward you. Find a spot where you can avoid getting a lot of extraneous ambient light in the picture, as this will cause an overexpose.
Set the camera on the tripod. Don't extend the legs or neck of the tripod. Keep everything close to the ground to keep the camera as steady as possible.
Ensure the camera settings are correct. It is best to set these well ahead of time, as it may be difficult to see your camera controls or your checklist in the dusk or dark. But it's wise to double-check now.
Set your focus to infinity. You're generally far enough away from fireworks that you can adjust your lens focus to infinity and leave it there. If you want to get a closeup of a small part of the burst, you may need to adjust the focus as you zoom in. If you want to include buildings or people in the background, you may want to bring these into focus. Avoid the use of auto focus if possible. Most cameras have difficulty adjusting focus in low light conditions.
Use a smaller aperture. Set the aperture in the f5.6 to f16 range. F8 is usually a good bet, but if you're shooting with ISO 200 film you may want to kick it up to f16.
Turn off your flash. The fireworks are bright enough, and your flash wouldn't effectively reach them anyway.
Take off any filters or lens cap before shooting. If your lens has IS (Canon) or VR (Nikon),Turn it off before shooting. If you are shooting with an SLR or DSLR camera, chances are your lens has the IS (image stabilization) or VR (vibration reduction) feature built in. And if you have IS or VR (it is essentially the same thing, but Canon and Nikon just had to label it differently), then chances are you are used to leaving it on close to 100% of the time - which is generally a good idea. IS/VR is meant to sense the vibration (the shaking of you hands, mostly) and compensate for it. When it does not sense any, it... creates it. Turn it off in order to get sharper images. This tip goes not only for shooting fireworks, but is valid any time you shoot off a tripod.
Frame the picture before shooting. Look through your viewfinder during the first few bursts and figure out where the action is. Point your camera at that spot and leave it there. You don't want to be looking through the viewfinder while you're trying to shoot, because you'll likely shake the camera or your timing will be off. If you're trying to get closeups, of course, your framing will need to be more exact and you'll probably have to play with it more. Once again, frame carefully to exclude other light sources that might distract from the fireworks or cause your photos to be overexposed. 5Keep the shutter open to capture the entire burst. Set the exposure to the maximum length. To get the sharpest image it is best that nothing comes in contact with the camera during the exposure. Use the automatic long exposure of 30 seconds or more. If your camera does not have an automatic long exposure the use of a cable release is OK. Use the BULB (B) setting, which will keep the shutter open as long as the button is depressed. A rule of thumb is to open the shutter as soon as you hear or see the rocket shooting into the sky and to leave it open until the burst is dissipating. This will usually take several seconds.
Spice it up. Even good pictures of fireworks can be boring if there's nothing to distinguish them. You can make more interesting photos by including buildings in the background or spectators in the foreground. Choose your shooting location to try to get an unusual and unique perspective on the show if Possible.
Hope it helps, if so do rate the solution
Posted on Dec 27, 2010
Geekman
  • 32281 Answers
SOURCE: my nikon D3100 got wet from rain...what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Posted on Jan 15, 2012
  • 6771 Answers
SOURCE: nikon d3100 showing no sd card inserted message even after inserting it..please help
The only thing I can think of remove the SD Card, start camera, and go into the menu, check to make sure there are no pictures on the internal memory, if there are! erase them and restart camera and power off, re-install card and hopefully you are good to go. If no change! have the camera shop run a quick check.
Posted on Mar 24, 2012
  • 102366 Answers
SOURCE: setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Posted on Nov 30, 2012
Hi Just been ripped off on ebay, don't know if anyone can help? Bought a firmware upgraded d3100 which apparently was done to give an improved bit rate. I asked the seller if it affected the
Hi Andrew - There are several hacked firmware files for this camera. Most that I have seen deal with allowing 3rd party battery usage, 17 minute video, unlimited video and variable shutter and aperture control during video recording. There may be others. I suggest you either (a) contact eBay and open a dispute resolution ticket to return the camera to get your money back or (b) try installing an authentic Nikon 3100 firmware from & as per instructions on the site:
https://support.nikonusa.com/app/answers/detail/a_id/18725
Understand that option (a) is preferential. If for some reason you can not do (a) then (b) would be the next step. Any time firmware is updated, there is a risk of damaging the hardware. This is especially true if power is removed during the process - but other things can happen, too. Finally, if (b) doesn't work for you then you may have to hack the firmware as shown in the link below (or your choice of hacks):
https://www.youtube.com/watch?v=ylQqH6Kfyno
Notes for this site are below:
Published on Feb 16, 2014
TheXtremesoundz Audio & Vision By Jason Brown.
Powered By Fullscreen.net™
Official Website: http://full.sc/14gAJqY
Facebook Page: http://full.sc/13mbQGW
Twitter Page : http://full.sc/14zB40R
Youtube Chan : http://full.sc/1cvLSGF
Upload Playlist : http://full.sc/1cvMk7y
Subscribe : http://full.sc/16uPmTy
Rate, Comment and Subscribe
__
*THIS ALSO WORKS ON NIKON D5100*
Finally after 4 years we have a hacked/custom firmware that enable full manual video control on the Nikon D3100 DSLR. Just like the D3200 or Canon 5D, 7D ect. you can simple adjust the shutter speed/angle and the ISO sensitivity of video as well as the usual aperture control. You can even adjust shutter speed while recording!
Download Link: http://simeonpilgrim.com/nikon-patch/...
__
Nov 20, 2014 | Nikon D3100 Digital Camera
Nikon d3100 collapsed during firmware update
Alexandru,
I think your camera is bricked. If you did remove the battery, and after charging it again, replaced it, and it still does nothing, you only have one option. Contact a certified Nikon service centre. Tell them you tried to update the firmware of your camera, and it then it stopped working. Tell them you did everything as described. First charged the battery and only then you started the procedure.
I think they can revive your camera, but perhaps you have to bring it in, or send it to them. Don't forget to ask in advance, what it will cost if they have to put in the firmware.
Success
May 14, 2014 | Nikon Cameras
Nikon d3100 stuck on flash mode
What do you mean by flash mode?
Have you read the manual how to use the camera?
If nothing from there helps, try connecting it via USB and check if there is firmware update. If even that doesn't help, try acessing menu and doing hard reset from there.
Mar 03, 2014 | Nikon D3100 Digital Camera
Arabic language
Go to Nikon website on your computer and download the language for your Nikon D3100 camera then use the usb cord to install it to your camera. Any problems with this go to ehow.com and they have other solutions too.
Aug 17, 2013 | Nikon D3100 Digital Camera
There is a green light thats on even with camera turned off and also the screen shows a rotating timer. Its a d3100
your Nikon has stuck in a loop and unable to shut down, this type problem should be looked at by camera tech.
Jan 26, 2013 | Nikon D3100 Digital Camera
Autofocus Lens for Nikon 70-300 1:4-5.6 AF25-166-4553 is mountable on a D3100?
You didn't specify the make of the lens. Assuming the lens has a Nikon mount then yes, it will mount on a D3100. The big question is whether it will autofocus on the D3100. The D3100 does not have an autofocus motor, relying on the lens to have one. Not all lenses do. Nikon designates lenses with an autofocus motor as AF-S. Other manufacturers use different designations.
If you need further assistance, feel free to reply to this post and give the make of the lens.
Mar 13, 2012 | Nikon D3100 Digital Camera
Trying to decide between purchasing a Nikon D80 or 3100....any advice?
The D3100 is newer, for what it's worth. It has LiveView and video capabilities.
The D3100 is intended for beginners, the D80 for more experienced users. The D3100 is easier to learn, the D80 is easier to use once you learn it. The D3100 is lighter, the D80 is more rugged.
The other major difference is that the D3100 does not have an autofocus motor, depending on the lens to have one. This means that some lenses (those not designated AF-S by Nikon) will not autofocus on the D3100 while they will on the D80.
The ultimate decision is up to you. Only you can decide which features are most important to you. Also, if you can, try to get your hands on the actual cameras. See which one feels more comfortable to you.
Jun 11, 2011 | Nikon Cameras
Nikon D3100 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
