Canon ir2022n error is coming left door/front cover open
Cogz
  • 1326 Answers
SOURCE: PAPER JAM
Open the front door and do you have a sorter on it? If so, you need to move it away. The finsher has a bracket and right under the bracket there is a handle pull the handle up and find you will see your jamed paper. Also, look at the duplex area under the transfer unit. It has a green handle lift it up and maybe find a jam there. You may have found it by now
Posted on Jul 18, 2008
Chittaranjan
  • 62 Answers
SOURCE: Error message coming up: The HP LaserJet 1020 has
send your printer for service. seems like, one or two sensors are malfunctioning.
Posted on Aug 09, 2009
  • 153 Answers
SOURCE: Hello, My canon image runner 500s copier error
put in toner then and close cover
Posted on Oct 02, 2009
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
Cogz
  • 1326 Answers
SOURCE: Canon IR2022N code 007's Solution
E007 means that the fixing film can not find "HP" for the film, You will need to replace the fixing film....Good Luck
Posted on Feb 27, 2013
Where is the waste toner box in canon ir 2870
is in the font cover (canon logo cover), open the toner bottle door and revome the screw located in the center, then in the front left side there in another screw in the upper corner, remove that too. slide to the left the front cover and you will see the waste toner bottle
May 22, 2014 | Canon imageRUNNER 2000 Copier
E 803 error in 3170
this is Door close error.
Check if the door's nose that goes into the sensor hole broken, check the door closed/open switch, Check on connection of the front cover open/close switch (SW3) , Replace the front cover open/close
switch.
It's hard to locate it without service manual, but... if you manage to remove the plastic cover over the toner inlet then you will be able to see the hole where the nose of the door ( inner side of the door ) goes into.
For service manual, You can send me the mail on emma.servis@gmail.com
Hope that helps!
Jul 25, 2011 | Canon Office Equipment & Supplies
Error code e007 on canon imagerunner 210s
that is code for damaged fixing film u will need a technician to replace the fixing film. or replace fixing unit( for that, open the front cover; open screw of down left side small cover, remove cover; detach connection on the upper left side.remove earthing screws and in the upper centre, fixing unit mounting screw. release feeder leaver oin right side.open left door, slide out fixing unit replace with a new one and revert whole process.)
Feb 07, 2011 | Canon imageRUNNER 210S Copier
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
ERROR 6000 ON MY CANON PRINTER MP550
The front panel was open ON MP550 and had been hit by the a recliner. There is a sensor on that front door that detects that it is open. I had to take the front door off, reach in the slot on the left side of the opening, slide the sensor back up, and reinstall the door while holding the sensor up. Error 6000 went away!!!
Nov 13, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Canon Image Runner 4570 Error Code Display E000019-0000 what this parbalm how can u salo this parbalm
E000019 means the waste toner is full. It needs to be emptied out. It is behind the front cover of the copier. There are two screws that hold it in place. Open the toner door and there is one screw there set into the plastic. The other one is on the top left coner of the cover, that may be out? Slide the cover to the left and the waste toner bottle is right there, milky white bottle. Pour it out carefully. Reinstall and turn the main power switch off then on and you are done
Jun 10, 2010 | Canon imageRUNNER 4570 Copier
I have an ImageRunner 2016i with the error E000019
the error E019, means that the waste toner is full.
Waste toner is excesive toner, wich is cleand from the drum at copy process, and goes in waste toner "compartment" in drum unit.
To clear the error and clean the waste toner, you need to:
Open front cover, open the left sideway door, by pressing the open button.Then, left from the toner is blue handle wich you need to lower.Then pull out the drum unit.
Then on top of the drum unit, you will be able to see one cork.Remove it and vacume the toner out.
Put back the cork, put the drum unit back in, close front cover, closse left door by pressing them on place where hand is ilustrated.
Turn copier off and on.
These will clear your error.
The instructions for drum unit removal are also illustrated on inner side of front cover, beneath toner replacing procedure.
Hope that helped.
May 26, 2010 | Canon imageRUNNER 2016i All-In-One Laser...
I have a problem with canon ir2016j photocopy, system error E019
E019 usually means the waste toner is full. I think its in the drum on these so a new drum will be required.
Drum is under the front cover.
Oct 22, 2009 | Canon iR 2016i Black and White Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
E001
on the machine open the front cover and put something in front door switch ,front left side there will be a small hole insert pin in that dollar sign will appear at display ,press *4* then by arrow keys select error at display and reset it
Oct 18, 2007 | Canon NP 6650II Copier
20 people viewed this question
k24674
jasbo
jasbo
