Question about LG DU-52SZ61D TV
I want to ic la7840 circuit diagram - LG DU-52SZ61D TV
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Https://www.google.com/search?q=la7840+circuit+diagram&tbm=isch&tbo=u&source=univ&sa=X&ei=wSFuU_2lIZOdyAScqILIDw&ved=0CCgQsAQ&biw=1920&bih=1104
Posted on May 10, 2014
Bpl prima 18hd2 tv circuit diagram
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name or the IC number used with your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 06, 2015 | Prima Televison & Video
Igo 20"tv using la7840 verticl line
Check all the solder terminals at the vertical output IC. Re-solder all of it by applying a little more solder to each solder terminals. If it do not help you, desolder out the vertical output IC, and check all the related components. Check and replace damaged one/s. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 10, 2014 | Televison & Video
Onida tv
Horizontal line on screen denotes the absensce of vertical sweep itself. Check the vertical output section circuit to LA7840. Check for any loose solder terminals. It will be best to measure the input voltage to that IC from the LOT secondary supply. Try by replace the IC. If these do not help you, measure the frequency from the main IC. It should be at 50Hz. If this frequency is not present, the main IC is faulty. If you wish to get some more details about the circuit, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Schematic diagrams, that show vertical IC LA7840 is given. You can compare it.
Jun 23, 2013 | Televison & Video
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Dec 07, 2010 | Panasonic TC-21Z88R 21" TV
Horizontal line in middle of the tube.. LA7840 vertical ic
Possible that the vertical drive IC has failed . But make sure to test the voltage on the IC as if the voltage is not present on the IC thenthe saem problem can happen andit can be due to a failure of the fusible resistor from the LOT.
So check this before you replace the IC.
Sep 24, 2010 | Televison & Video
What is the price of lg tv ic la7840
hie can anyone help im looking for lg tv ic which are tv model 8993-32d,parts are cpx750097,tpu30505b3,msp3410dc5
pls pls help im stuck.
Sep 20, 2010 | LG Televison & Video
Shut off itself
sounds like you might have an auto overvoltage shutdown circuit kicking in. The hivoltage goes to high and the monitoring circuit auto shuts down. More than likely trouble is in hivoltage circuitry. If you have a transformer that will allow you to bring up the set slowly without shutting down and you can look to see what's happening.
Feb 16, 2009 | Sharp 25R-S100 25" TV
JVC AV-27020 TV Blinking LED, Static Electricity on tube but no sound and image
Sounds like a bad main regulator IC.. Try putting a 100 watt light bulb across the main AC fuse, turn on the set and see if it will stay on longer. If it does, replace the main regulator iC. If it does not, then it could be almost anything in the sweep section of the set, and or in the regulation circuit of the power supply. Look for slightly swollen capacitors in the set. good Luck please do not forget to rate this thread.
Dec 10, 2006 | JVC AV-27020 TV
LG DU-52SZ61D TV Logo
90 people viewed this question
Computer Repairing
Computer Repairing
