Question about Briggs & Stratton Briggs and Stratton 30335 4000 Watt Briggs Stratton Pro Generator
Model o3o319 portable generator not getting gas or air has spark
If I inject gas in carburator it runs for a couple of seconds.
    Problem Solver:
  • 15 Answers
Your filter inside tank may be clogged take aome air and blow in the out let of gas to see if it maybe dirty. check the fuel line itself maybe weak inside and collaisping and not allowing fuel.
Posted on Feb 02, 2015
2 Suggested Answers
SOURCE: My Briggs 10 HP Generator is outside and covered
Don't leave gas in the tank, or add additive to gas >>> you know that but the next reader might not know.
If you are able to get washer running by spraying WD-40 or some other accelerant directly into carburetor but engine will not continue running ... there are 3 suspects: 1) dirty air filter 2) the exhaust port is clogged with carbon, dirt, etc 3) the carburetor has given out or no gas is getting to carburetor
2) Check exhaust port >>> we finally broke the screen out with a screwdriver so it wouldn't bother us any more
3) Carburetor ... you have spark but the gas is either not getting to carburetor or carburetor is not letting gas in. Pull off rubber line going to carburetor and see if gas flows out. If gas gets to carburetor and all the conditions above are met, then the carburetor needs gum out or rebuilding or replacement
Posted on Oct 16, 2010
Why porter cable h450is generator won't start
If it starts initially, then it has spark. most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 07, 2014 | Porter Cable 4,500 Watt 9 Hp Portable...
Generator starts and runs in choke position only. shuts down in run position.
There is fault in the fuel settings, you might need to remove and clean the carburator, clean the air filter and also check if the oil is clogged.
Also remove the plug and check for dirt electrode tips, if so the spark plug must be replaced. Set with the correct gap , test for the spark before it is replaced.
Also check if there is impurities on the fuel. The carburator resetting must be done with care and take help if needed.
Nov 07, 2011 | Coleman Powermate Premium Plus 6250W...
Powermate plus 1750 portable generator. Has fresh gas, will just runs a couple of seconds on starter fluid and just stops.
It could be a number of thinks. plugged fuel line, carburetor, but dont use to much starter fluid this can burn a hole in the top of your piston. check to see if its getting any spark.
Aug 14, 2011 | Coleman Powermate Premium Plus 6250W...
My Subaru backup generator won't start. It started fine last year and ran for about a few days. When I stored it I just shut it off and put it away, didn't add any additives or anything, now it...
you need to take the carburator off and clean it as well as the fuel tank,to start,maybe even a spark plug as well.always use a gas stable additive when you store it,better yet try to get in the habbit of running it once a month
Jun 12, 2011 | Coleman Powermate Subaru 5000W Portable...
Motor was loping i cleaned plug and filter now it runs like 3 min n quits
carburator needs to be cleaned,and put new fuel in the tank as well as a gas stable product
Jun 07, 2011 | Briggs Stratton Portable Generator 305cc...
My Briggs 10 HP Generator is outside and covered and wont start. It will run with gas sprayed directly in the carburator throat bit not on its own. I have just installed a carburator kit and a new spark...
Oct 16, 2010 | Briggs & Stratton Briggs Stratton 6200...
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
It started but when i pluged in ti it it quit. has not started since. checked plug and it was loaded with gas. install new plug and tried. check spark and it appears eratic. pulled air filter off and it is...
sounds like the float is stuck, how long has it ben setting around? try some carburetor cleaner. spray the carburetor down. empty the fuel tank put fresh fuel with fuel treatment. you may have to remove the spark plug, pull starter string a couple of times to clear out cylinder make sure spark plug is dry put back in and try to start the generator.
Dec 10, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Generator doesn't start
Hi
Check the spark at the plug,compression and carburation.Priming the engine,putb some gas in the cilinder and start the engine.If the engine runs only the gas you puted in the cilinder you have a delivery problem to find and fix.Remove the carb,disassembly and clean it,check and clean the air and gas filters.
best regards savumihai71
Jan 11, 2009 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Briggs and Stratton 30335 4000 Watt Briggs  Stratton Pro Generator Logo
107 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
