Instruction manual for Micromark 30114 oil filled radiator
I am needing an instruction manual for oil filled radiator Brand: Micromark Model#: 30114
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
Roger NB Jr
SOURCE: Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Posted on Nov 22, 2008
  • 259 Answers
SOURCE: Delonghi HMW2400T oil filled radiator with no operating manual
if the timer is working when it gets to the off/on position you will hear a click so to test it just turn the timer around slowly until you hear the click much like an alarm clock that has the alarm turned off hope this helps regards Jim
Posted on Apr 14, 2009
SOURCE: Kenwood oil filled radiator heater - digital
My EW6708K stopped working after a power outage (was not on at the time, just plugged in). I couldn't find any info online. So I used my last option: I took it apart. Two screws on the bottom opens the unit's electronics. Two more screws inside to get tol the circuit board. I was looking for a reset button. There was a tiny white “thing” on the circuit board. I pressed it and reassembled the unit. That did the trick! Simple. Just be neat and put everything back the way it was.
Posted on Jan 25, 2010
SOURCE: Need Instruction Manual, Kenwood Electronic Heater #EW6708K
I have an original Kenwood instruction Manual for the Model
EW6708EK oil filled electronic heater (eng. and spanish)
Posted on Feb 02, 2010
I need a safety user manual for a delonghi rapido oil filled radiator
probably need to take radiator back to store and trade for another one, most time when you buy new electric appliance all inside paper work like warranty,operation instruction manual should be inside package if not, need go back to the store where you purchased radiator, they should give you another operation instruction manual and warranty paper work or give you whole new entire radiator take back the other radiator.
Dec 12, 2011 | Heating & Cooling
I inherited this heater with no manual and am in need of some instructions on how to properly use it and how to set temperature etc.
Go to Delonghi web site http://www.delonghi.com/ select country you are in. Select Customer servivices and then Down load instruction manuals. Hope this helps.
Aug 09, 2010 | DeLonghi TRN1015T Solaris Oil-Filled...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
I have a micromark mm23244 alarm and have lost the instrustons, need the reset code so i can use it as some1 tryed to get in the house last night tyx
You can find most user instruction manuals at, www.managemyhome.com.
You will need the model number off the unit. The search box is on the right side of the page.
Jul 05, 2009 | Micromark England Microcooler Plus Compact...
Nov 21, 2008 | Heating & Cooling
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Warm up
if you go here you can download user manual..
enter brand and then model.
i used one last year and it ran continuous with no problems.
Sep 20, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
