Question about Kitchen Ranges
My stove burner turns on for a cpule of seconds then it shuts off, about a minute later it tries to turn it self on and same thing happens. everything else works just fine all top burners and the broiler
  • gerbee gomez May 11, 2010
    gas or electric?
Its the capacitor underneath the pcb it will cost about 50 pence to purchase from maplins, remember to fit it the right way round, the one you will get is three times the size of the original but it will solve the problem, Mike
Posted on Sep 29, 2009
Why wont second ring wont turn off
It should have a shut off valve on the left side. You should turn it clock wise and turn off the second burner c32cb27e-6bff-49c1-b3fe-ba672eaf151e.jpg
Jun 13, 2014 | Coleman 425e Camping Stove White Gas Duel...
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Dec 01, 2012 | Whirlpool GW395 Gas Kitchen Range
Baking
I sounds like an issue with the pilot light. Our stove does the same. Sorry that's not much help
Jul 23, 2012 | Jenn-Air JES9750 Electric Kitchen Range
Gas oven gas not shutting off
sounds like you got some debri in the safty valve, teflon tape or pipe dope. they don't come apart so you will probly have to replace it. sorry! disconect lines and blow out good befor replacing it so it don't happen to the new one
Dec 25, 2009 | Ovens
All of the burners on my range started flikering at the same time and they were off. I could not stop them. I saw a little smoke escaping from the rear right burner. It finally stopped flickering and now...
yikes .. you have a very dangerous condition there ... ventalate the area and turn the gas off immediatly.. there is a shutoff valve somewhere in the gas line coming to the stove top .. if you cant find that then shut off the gas at the gas meter or call the gas company to do that for you (its free) ...
your problem is likely a loose pipe or cracked manafold .. it is leaking gas under the cooktop .. i would replumb the unit and check for cracks .. or call a professional .. your unit comes with a 1 year warranty or an additional 4 years if you bought extra coverage .. that probably wont cover a bad installation if thats the problem (unless the repair company installed the unit to start with) .. but will cover the stoves inside plumbing ..
your stove is not safe the way it is .. if you can still smell gas then you shouldnt be in the house until the gas is turned off ... windows should be open .. dont turn on lights or other things that can ignite the gas .. and absolutely dont try to relight the burners until the problem is fixed ..
Nov 12, 2009 | Maytag MGC5536 Gas Cooktop
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stove top difficult to light
your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Feb 21, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
