Question about Ragim Archery Ragim Antelope Limbs
What is the recommended brace height for the Ragim Antelope now?
Antelope draw results
Dennis, Antelope draw results, you would have to contact your Fish and Game office for this info. Try using Google search for your area.
Saskatchewan Resident Big Game Draw Hunting Government of Saskatchewan
Draws Summary Report 2016
Conserving Wildlife Serving People
Idaho Fish and Game Controlled Hunt Results
Aug 20, 2016 | Miscellaneous
How to attache a lean two to your house
Put a 4x2 the length of ur lean to fix to wall with large 3/8"x5" long bolts an plugs in wall if brick if timber then screw in to that, at a height u want to have the lean,.. to make a mark with a friend place timber with level on and mark wall drill the 4x2,, to take fixings 18" apart along the length then fix to wall, then u will need 2 or 3 up rights to hold roof up u will also need several cross timbers to take roof panels make sure u have a slight fall on roof to out side so rain runs of u will need cross bracing fix wall plat thats what the 4x2 is called up rights in ground add cross bracing then put all others bracing at even spaces in b tween then when all is tight put panels or plastic sheet on roof making
May 07, 2014 | Washing Machines
List of african antelopes
African antelope list kewel, kob, kirks dik, klipspringer and kudu
Apr 29, 2014 | Basketball
What can be done to correct teeth alignment?
For getting a correct alignment of teeth, you can prefer the best Invisalign treatment provided by Invisalign Braces London.
This treatment can be used to cure issues like spaced teeth, over crowding, over bite, cross bite, under bite, etc.
This is a painless, discreet and easy way to get rid of irregular teeth alignment and hence to get a better smile. incognito-braces-3-1-768x485-e0k1pw3p4z3zeofet4nxgtte-2-0.jpg
Oct 11, 2013 | Cars & Trucks
Where can I find a brace for moderate stability of a ligament?
I would recommend the DonJoy Deluxe Hinged Knee Brace. You can find it for $119.99 on http://www.betterbraces.com
Apr 22, 2013 | Health & Beauty
What is brace height?
Brace height is the distance, when the bow is at rest, from the string to the deepest point of the grip. Today's bows generally range from 5-1/2" to 8-1/2"
Jul 09, 2012 | Archery
Where do you add power steering fluid for a 2000 Buick Regal LA
The power steering filler cap is on the passenger side just behind and under the alternator (I had to use a flashlight to find mine but it's visible if you lean over the front fender - passenger side). . There is a cross brace by the firewall that I had to remove so I could get to the filler cap. The cross brace is held on by 4 nuts - 1/2" or 13mm - and removing them and the brace allows fairly easy access to the filler cap. Remove the cap and fill. I'd recommend using a small funnel since it's virtually impossible to get the power steering fluid bottle behind the alternator and around several hoses. A funnel made it a cinch. Check to be sure you don't over fill, replace the cross brace and you're finished.
Dec 13, 2009 | 2000 Buick Regal
Bear polar recurve brace height
String length is 60 inches. The brace should be 7.5 to 8 inches. Listen for noise and feel for hand shock. Twist the string to add brace. Shoot for the sweet spot. When the bow becomes quiet and the vibration and hand shock is minimal, you have found the sweet spot. Measure your brace height at this point and write it down.
Mar 30, 2009 | Sport & Outdoor - Others
Fuel Tank
carfully ,, buy a repair manual,, why are you removing it.??? leak or bad pump.. ?? be careful of hoses and wires to get them back on correctly.
Drain, disconnect, lower , reverse??
Jun 10, 2008 | 1998 Pontiac Sunfire
Washing machine jumping
if its a new machine did you remove the shipping braces
Mar 11, 2008 | Washing Machines
Ragim Archery Ragim Antelope Limbs Logo
458 people viewed this question
Top Ragim Archery Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Don A
Don A
Are you a Ragim Archery Archery Expert? Answer questions, earn points and help others
