Question about Logitech X-230 Computer Speakers
No sound at all, but power on. Should I replace the phone jack?
At first only one of the speakers didn't work unless I twisted the cable that goes into the jack in the computer. Then the other speaker and the subwoofer stopped producing any sound, which happened at the same time. There's absolutely no sound, not even if I touch the jack with my fingers. I tried different sound sources and also tried with headsets plugged into the speaker. The light on the speaker signals that there is power.I have also opened up the speakers and the soldering looks pretty solid, allthough I admittedly don't know alot about soldering. Can I just assume that the cable or the phone jack that goes into my computer is the problem and replace that? I dont have any tools to test if that cable is the problem and I don't wanna replace it and find out it wasn't even broken. Many thanks!!
  • Logitech Master
  • 1,381 Answers
Hi Hermann ,
This is a typical issue with Logitech speakers . You need to bring them back to the the dealer and get an exchange set for free replacement onder warranty . If the warranty has expired , you will need to solve the problem by testing the cables or the printcircuit inside the sub , BUT first connect your head phones or another speakers set to the correct output of your computer's soundcard to verify if the issue actually commes from the speakers . If the test is negative , the issue is to be found in the soundcard and you will need to replace it .
Best regards .
Posted on May 12, 2014
Testimonial: "As I stated above, I have tested with different devices, so I'm sure the problem lies with the speakers. Would you concur then, that it's most likely a problem of the input cable/jack?"
  • 4 more comments
  • fanaudi
    fanaudi May 12, 2014
    Yes , most likely , as you said , baring in mind that the light
  • fanaudi
    baring in mind that the light says on . Has the warranty expired ?
  • fanaudi
    baring in mind that the light stays on . Has the warranty expired ?
  • Hermann Schmaerig
    Hermann Schmaerig May 12, 2014
    Yes it has expired, so guarantee is not an option.
  • fanaudi
    fanaudi May 13, 2014
    O.k. I would disconnect the current jack cable from it's input . Find or borrow a similar cable and sold its ends directly to the existing ones inside the sub . Reduce the speakers volume on pc to zero . Connect the jack of replacement cable to the output of the soundcard and see what happens when playing sound and carefully and gradually increasing volume sound of pc . If it's working , you need to replace the cables ; if not , the amplifier is the problem .
  • Hermann Schmaerig
    Hermann Schmaerig May 13, 2014
    Ok thanks!
SOURCE: right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Posted on Jun 11, 2008
SOURCE: Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Posted on Jan 24, 2009
night71
  • 328 Answers
SOURCE: One speaker works only
As long as the jack you are using fits snug into the port, they will be the right size. I am sure that they are the same size. As for the jack port, some can be finicky like that. It is more than likely your sound card that is at fault. You can check the connection on your card by removing it with the computer off and inspect it for a loose connection within the jack port and around it. Plug in the speakers slowly and see where it is not contacting. Some do it yourselfers can fix this by replacing the port or re soldering a bad connection
Posted on Nov 19, 2007
  • 7 Answers
SOURCE: x-530 one speaker not working
this is a problem that i have faced as well it is likely that the cable going in to the jack could be loose and you might need to move it a bit, but in your case i think most likely would be that the input jack on the sub for the speaker is broken in that case you should call up logitech and ask technical support to see what they can do for you should be covered by warranty!
Posted on Feb 11, 2009
  • 4 Answers
SOURCE: No sound coming out of speaker, but headphone jack works!
Hi, I had the same exact problem. The speakers wouldn't work but sound came out of the headphone jack.
To fix my problem, i opened up the subwoofer unit and checked the fuse on the circuit board which seemed fine. Then i had a look at the wiring on the other side of the circuit board and noticed one of the wiring had fried leaving a gap in the connection and exposing the copper wiring. So i just soldered the two bits of wire together. Works fine now!  I just had to be careful when i finished soldering that the exposed wire wouldn't touch any of the other connections. I insulated the wires with a glue gun to keep it all in place.
hope this helps.
Posted on Feb 25, 2009
Noise, I get a buzzing noise out of my speakers when i hook up my interface with a jack cable any help ?
If the buzzing is louder or softer, directly relative to the volume level, it is signal interference.
99% of the time, when you get the buzzing or "air" sound, it's the cable. To give you an idea of how serious this is, each of my speakers has a Monster THX Ultra 1000 speaker wire running to it, which can cost roughly $100.00 each. This is for the sole purpose of eliminating that air noise or buzzing.
When running speaker cables or AV cables, you don't want them to run parallel to each other, unless they are several feet apart. If they have to cross paths, you want them to cross perfectly perpendicular to each other so as to minimize the amount of contact they may have.
Speaker wire should also be twisted copper (unless running fiber optic cable, which would be extremely rare). Many people try to use solid strand, but a lot of the signal is lost, even when well insulated.
If your speakers are close to anything electronic, try to move them away from the source, or move the source from the speakers.
If you have a GSM phone, the phone can cause distortion in your speakers as well, but with the newer phones, that only happens when it reverts to the older tower technology.
It could be the source of your sound input as well. If you have a bad connection at the source (assuming your computer?), or the source itself just isn't a very good quality, this can also cause that buzzing or air sound.
Hope this helps.
Oct 21, 2013 | Akai RPM3
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
DOES LG 37" MODEL # 37LB4DS-UA.AUSLLJM HAVE A HEAD PHONE JACK
On the back of the tv and the cable box should be red, white and yellow rca jack, the white and yellow are sound
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 19, 2012 | LG M2280D 22 in. LCD TV
Can't them to work on my tv after plugging them into the 3.5mm audio out jack
Excuse me if I'm sounding a bit dumb, but don't these speakers need to be powered by an external power supply (You didn't give the model but I'm almost 100% sure they do). if so are they connected to power? And if they are (again, you didn't give the make and model of your TV) are you sure it's an output and not an input jack?
Simple things of course but sometimes overlooked.
Regards,
Mikeywaf
Apr 21, 2011 | Insignia 2.1 Speaker System (3-Piece)
The speakers on my monitor dont work but if i plug headphones in th back of my computer i have sound.had sound in the eveningbut in the morning had nothing is my moniter dead??
First try wiggling and twisting the the mini jack in the socket, that feeds the monitor speakers signal.
Both ends.. at the PC and at the monitor. Hopefully it's that simple.
The other thing to check is - Do you have a seperate power supply for the speakers? Ck it's still plugged in, to the power, and to the speaker feed.
Test the output with a meter to see if it failed. This can be replaced. (Would be cheaper to buy new speakers)
IF no joy at this point, it possible the speaker circuit in the monitor has failed, or the internal power feed to the speakers (if no external one)
Replacement external speakers are not at all expensive, unless you really need Hi Fidelity. That seems unlikely, as you are using monitor speakers which are as poor fidelity as most come.
I'll bet a $25 set of external speakers will sound 10 time better than the monitor ones.
Feb 10, 2011 | Computers & Internet
DELL SPEAKER SYSTEM STOPPED WORKING
Suggest you abandon the mini-phone jack connection - sounds like a wire is broken in that connector. Use the RCA stereo outputs from your TV into the Dell surround system. You may need a couple of adapter cables to make that work. Take photos of the connectors on the back of your TV and on the back of the Dell Surround system. Take those to an electronics store like Best Buy and ask for help there to get the cables you need (telling them that the mini-phone (headphone) plug is giving you trouble.
Apr 22, 2017 | Dell 5650 Computer Speakers
Audio cuts in and out in media center or while watching a dvd
Check to ensure that the speaker connection plug is fully inserted into the speaker jack on the computer. Do the same for the power connection at the speaker, too. Slightly wiggle or twist the connections and wires - one at a time to isolate the source of the failure (can be the power plug or wire, audio plug or wire, or even the jack on the PC . If related to the speaker plug, try using the speakers in another speaker jack on the PC - or other device (mp3 player, etc.) if the problem is still present on both locations, it is related to the speakers / power. Try using a pair of headphones plugged directly into the speaker jack on the PC to see if the problem is present still. If the problem is common to both speaker and headphones, the jack on the PC is likely the culprit, and a new sound card will probably have to be installed. Otherwise, replace / repair the speaker cable, plug or system.
The likely source of the problem is a stretched wire along the cord - or at the plug. A repair can be attempted if desired - or replace the speaker system if lacking tools or if unsure how to go about it.
Sep 28, 2009 | Gateway GT5016E (RBGT5016E) PC Desktop
I HAVE A DELL OPTIPLEX 170L WITH BA735 SPEAKERS BUT i HAVE NO SOUND
Make sure you have a sound card installed
    • you think you have a sound card installed but you don’t see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
  1. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
  2. Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
If these steps don’t solve the problem, check the information that came with your computer and speakers or go to the manufacturer's website.
Aug 17, 2009 | Audio Players & Recorders
Girlfriends computer
the phone jack should be on a seperate card, but the speaker jack goes into the Green connector at the rear of the tower
Sep 08, 2008 | Acer Aspire™ T180 PC Desktop
Logitech X-230 Computer Speakers Logo
162 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
