Question about Sewing Machines
How can I fix my necchi 4595 sewing machine that has Reverse button stuck and can only go in reverse
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
SOURCE: reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Posted on Feb 04, 2008
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
  • 152 Answers
SOURCE: Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Posted on Oct 07, 2009
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
I have a necchi 3205f royal series how do I use the reverse button?
The reverse button may be used to complete a buttonhole, or to finish a row by moving back and forward. Try it out on an old piece of cloth first.
Jul 28, 2014 | Necchi Sewing Machines
Can't turn wheel
Check the area that contains the bobbin. There might be something loose in there. While you\'re in there, clean an oil this area. Also, open the end cover (left side of machine) and lubricate the swivel arm top and bottom and wait overnight for oil penetration; you can also use a hair blow dryer to speed this up. For oiling diagram, see:
http://sewing-machines.blogspot.com/2009/11/necchi-zig-zag-issue.html
Feb 15, 2014 | Necchi 4595 Mechanical Sewing Machine
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
I can't find reverse on my necchi 536fb. I inhereted the machine it's pretty old but works great. Sewing would be much easier if i had a forward/reverse button. Thx
Hi! Sewing is so much easier with a forward/reverse button! :-) I have a Necchi 536 fb also. Here's a picture of mine: efebd8b.jpg
The knob on the lower right controls the stitch length and forward/reverse. Push the center part in to get reverse and release it to go forward again.
You really need a manual for your machine--my Miss Sophia came from a pawn shop so I ordered one from relics.com (http://pages.sewing-machine-manuals.com/173/PictPage/1923115740.html) for $17.00.
I love my Necchi--you can read about her at www.robbiesews.blogspot.com if you like.
Happy Sewing!
Robbie
Apr 22, 2010 | Necchi 3101 Mechanical Sewing Machine
Have a Necchi 4595, need help
Increase the pressure on the presser bar. Usually this is located right above on the top of the machine.
May 18, 2009 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
