Question about Hoover UltraCare HC6 160E Front Load Washer
Why does my Hoover Ultracare washing machine keep going to Caresse mode ?
Whilst using the 29min program, my machine often stops and changes to caresse mode. How do I stop this happening
  • 1294 Answers
SOURCE: hoover ultracare 1500 not emptying
Suggestion: First plug off the wall. Remove the back panel of the machine. Check to see it the thin tube going from the top control panel to the exit side below the machine is block free. To check disconnect this from the top and blow into it. It should not blocked, refit. This is the water level control. Secondly check out your pump.
Posted on Sep 17, 2007
SOURCE: hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
Posted on Jun 17, 2008
  • 351 Answers
SOURCE: hoover washing machine 550mb keep
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Posted on Oct 09, 2008
barkencoa
  • 3463 Answers
SOURCE: my hoover optima washing machine
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
Posted on Dec 18, 2008
garing
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
My Hoover UltraCare 1500 washing machine keeps repeating the spin cycle, even when I turn the programme control knob to stop
Sounds like the timer control switch is messed up. I had the same thing happen to my washer because my roommate was impatient and tried to spin the timer like the big wheel on the Price is Right. The plastic tabs broke and the timer died.
Jan 28, 2015 | Hoover Washing Machines
Hoover ultracare 1300 large load stopping mid cycle at a variety of different points and having to be manually stopped and started again at another point to complete the wash
Checkout your filter at the bottom of the machine, undo the bottom flap below the door, front. Plug off the wall mains socket. Be prepared for a lot of water so keep plastic bag, towels ready. Unscrew the plug you see to make water flow into bag; when all water has been disposed off, clean this filter & inside, refit carefully.
Feb 13, 2010 | Hoover UltraCare HC6 130M Front Load...
Need an instruction book for a Hoover UltraCare 1500 Washing Machine
http://service.hoover.co.uk/manuals/
using this address follow the promts
Jan 17, 2010 | Washing Machines
My Hoover Ultracare 1300 washing machine has just stopped before the spin - full of water. I have tried several options but can't get it to move at all from that. It will rinse and move clothes around, but...
Yes. the pump may be blocked. look at the bottom of the washing machine front and you will see a flap undoo this and take out any bitts stuck in. Caution. Make sure the washing machine is un pluged and when you unscrew that plug. all of the water will come out of the machine. Best to do it outside. If that dose not work it means the pump has blown.
Dec 15, 2009 | Hoover UltraCare HC6 130M Front Load...
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Hoover ultracare 1500 not emptying
Sep 17, 2007 | Hoover UltraCare HC6 150M Front Load...
Hoover UltraCare HC6 160E Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
