Question about KitchenAid Kitchen Appliances - Others
Dough stuck in kitchen aid pasta press - KitchenAid Kitchen Appliances - Others
3 Suggested Answers
SOURCE: I have Moulinex Regal pasta and dough maker. It
Here is an address for their customer service, you could write to them. I don't know if it is still a valid address. I am going to send a letter to them requesting information on ordering the standard discs. I only have the linguine one.
Moulinex Regal, Inc. Customer Service Dept 2820 Crusader Circle Virginia Beach, VA 23456
Posted on Apr 21, 2010
SOURCE: we need to find a
Here's my solution. I purchased an 8mm zinc-plated brass hex standoff from http://www.mcmaster.com (part number 92080A053). It is 25mm in length and has internal threads for an M4 screw. It fit perfectly into the nylon gear plug without modification. I had a colleague from work bore out a hole with his drill press (removing the internal threads) and turn down the exterior with a lathe to create a weak spot (mechanical fuse). See the attached image for the finished product. It doesn't match the original dimensions exactly but it is close and will suffice. You don't necessarily have to do the extra machining work if you don't have access to that equipment, but as jeffrey_w325 states in his post, this part is supposed to be the weak link and fail first. If you don't machine the part down, just be extra careful when using the pasta attachment. Good luck!4_3_2012_1_04_19_am.jpg
Posted on Apr 03, 2012
Tripped circuit & heard pop on KA Artisan Mixer #RRK150 while using pasta press attachment. Now doesn't run. Fixable OR replace?
probably fixable. The load of the pasta press may have blown an internal fuse or overheat thermostat, taking the breaker with it. Open it up and take a look.
Kitchen Aid Artisan Mixer RRK150 spares Google Search
Apr 23, 2017 | Food Mixers
The knob on my kitchen aid pasta roller keeps getting stuck and i cant change the setting i need to be at
It needs either oil or the gear has slipped. A machine repair person, such as a sewing machine repair might be able to help you out for a small fee. Good Luck!
Oct 27, 2013 | KitchenAid Kitchen Aid Ravioli Pasta...
Cutter does not cut all the way through the dough
Luckily, I have two manual noodle makers, the same brand..with opposite working rollers ...so, using the two units at once, is going to work for me...heck man, I just bought the darn thing last month from ebay...
I thought that maybe just maybe I had a piece of floured crap, causing the cog or gear to stick..
Sandy
Oct 09, 2013 | KitchenAid Pasta Roller / Cutter Set
Kitchen aid pasta roller is locking up
You will need to follow your nose and carefully dismantle it to see where the fault is. As far as I am aware Kitchen Aid supply no parts for this accessory, it comes as a complete unit only.
Mar 24, 2013 | KitchenAid Pasta Roller Attachment
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
Dough cracks when I insert the top cover into the grid
That is usually a sign of too little moisture. Try adding to or brushing the dough with water prior to pressing.
Dec 24, 2010 | Norpro Ravioli Pasta Maker Press Recipes ...
Are there instructions for the Norpro ravioli attachment? I have a Norpro two piece set attachment for my Norpro pasta maker. It came with no instructions whatsoever. Are there any printed instructions...
Just bought one,so you're in luck lol.
Roll pasta dough until thin and translucent.
Dust lightly with flour.
Cut dough into four rectangular strips,each about 12 inches by 4 inches.
Place on strip of dough over the frame.(the metal part)
Press dough into frame with the indented tray.(plastic piece)
Remove the indented tray.
Fill pouches as desired.
Place a second strip of dough over the strip with the filling in it and press strips together with your fingers.
With a rolling pin,roll across the dough covered frame,gently at first and then increase pressure until the zig zag edges of the frame are visible through the pasta. The ravioli is now sealed. Remove excess dough and re-roll.
Remove ravioli from frame by by tapping it on counter.
I find that these instructions aren't the best. They should tell you to lightly flour the frame before using or else it's hard to remove the ravioli. I also find that tapping it makes no difference...I always have to push them out through the bottom.
Good luck and enjoy!
Oct 05, 2009 | Norpro Ravioli Maker & Press W/ Recipes &...
I have an old vitantonio tortellini maker (model #520) but i have lost the instruction manual
1. Make your favotite pasta dough, roll out thin.
2. Place a sheet of rolled-out pasta dough on the metal plate, press down with the plastic mold to create the ravioli pockets.
3. Fill the pockets with your choice of mixture (cheeses, meats, spinach).
4. Then brush the top of the pasta sheet with egg wash or water and place a second sheet of pasta dough over the first.
5. Then use a rolling pin to press down on the assembled raviolis.
6. The pressure of the rolling pin will adhere the two sheets of pasta together and will cut the raviolis apart along the edges of the metal plate.
7. The result is a dozen perfect homemade raviolis!
Sep 27, 2009 | Kitchen Appliances - Others
My 12 cup kitchen aid food processor dough blade is seriously stuck inside the bowl after I made some dough. How do I get it out?
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Sep 17, 2009 | KitchenAid Food Processors
Kitchen Appliances - Others Logo
102 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
